Old 04-13-2022, 09:37 PM   #29
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
This is definitely a build to watch. I hope you can share as much as you're willing to.
Is there more the the A10 now? I thought I read/saw/etc. that all that's available were the clutches or something... Maybe that was the C8 DCT... Whatever.
Is CSP doing this build for you, too?
Yep, they've specced the entire build out. The A10 rebuild they don't do in house. I forget then name of the company but its a complete overhaul. New clutches, etc.
The port injection is of course using the too high psi plates, injectors etc. I believe they will modify my low side system a bit. I already have a holley 100gph low side. Full long block is built and tested/dynoed by LME. Cam specs I will go over with them after as i want to be able to drive it on the street.
I honestly really don't need the 1800hp block, but it is the best long block LME has for the ltx and has pretty much the best crank/rods etc. I figure if i am going to spend the money, just do it right just in case. Also in my opinion i think they are one of the best LTx engine builders out there.
Ill keep everyone updated. I'm just not sure if this is something i want to do now as summer approaches or wait until fall.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 04-13-2022, 09:39 PM   #30
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Originally Posted by Dan82679 View Post
I have the toohigh spacers with the holley on the stock x ported supercharcher and I can run full E-85. I'm at 800 wheel .
I see your in NJ, did you have someone local do it? Any issues with your port injection?
Old 04-14-2022, 04:35 AM   #31
Dan82679
Dan82679's Avatar
Drives: 2017 ZL1
[QUOTE=Camaro1973;11160674]I see your in NJ, did you have someone local do it? Any issues with your port injection?
Complete street performance...no problems at all.
Dan82679 is offline   Reply With Quote
Old 04-14-2022, 11:16 AM   #32
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
[QUOTE=Dan82679;11160739]
Yeah they've been doing all my works for a few years now.
People think just because its a small shop and they make a some you tube videos they are tools.... AKA Jack. (EDF HOBBIES)
Meanwhile there's a line of 50+ cars waiting for work outside.
Old 04-14-2022, 03:44 PM   #33
L78toLT1
L78toLT1's Avatar
Over the top build, Mike! I PMed you a few weeks ago to inquire about your gen2 Gesi cats. If they can take the heat from this build, they should last forever on my comparatively puny 720ish whp motor. Good luck on the new build and don't be shy about posting pics. If there has ever been a good candidate for a build thread, this is certainly it!
Baby Blue
Old 04-14-2022, 05:58 PM   #34
Dan82679
Dan82679's Avatar
Drives: 2017 ZL1
[QUOTE=Camaro1973;11160934]
CSP has 50 cars at all times,not small at all.
Old 04-14-2022, 06:47 PM   #35
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
[QUOTE=Dan82679;11161135]
Small as in size. (Compared to some bigger shop names) They do have the new space on other side now which is nice.
Old 04-14-2022, 06:48 PM   #36
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Hey bud thanks, yeah i'm going to test those cats on the new build too. LOL. They say 800hp per bank so lets see what happens
Old 04-14-2022, 07:36 PM   #37
Z OH 6
Drives: 2024 CT5-V Blackwing
I'm currently catless. I ended up taking off my Kooks green cats. After inspecting them after being on for 4K miles, they weren't melted but I could see a little of the mesh inside that looked like it was starting to bend. I doubt it was affecting performance yet, but I figured it was safer to take them off for now. I would like to eventually move to the GESI cats you're running, just hard to swallow the cost for something that gains me no power at all over catless.
Old 04-14-2022, 10:13 PM   #38
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Yep, this is exactly how it starts. Once the material gets pushed in it will continue to get worse.
I wanted cats for 2 reasons:
1. Cant stand smell of raw fuel (cammed even worse)
2. Noise level was insane with no cats and resonators, NPP. Noise was very loud.
I'm at 850 with E and so far these cats look new.
Old 04-15-2022, 04:34 AM   #39
Z OH 6
No question, the smell is worse and that's the main reason for considering the GESI cats that you have.
Old 04-16-2022, 10:52 AM   #40
ZL1Atlanta
ZL1Atlanta's Avatar
Drives: 2017 Chevrolet Camaro ZL1
The THP port injection plates work great, no concerns at all. What are you doing for the low side?
2017 ZL1 - PB 7.85 @ 175 MPH @ 3682 lbs @ 1313 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned
ZL1Atlanta is online now   Reply With Quote
Old 04-16-2022, 11:06 AM   #41
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Currently have a Holley 100GPH aux system. CSP mentioned they’ll be making a few changes to this but I didn’t go into detail with them on it just yet.
Old 04-16-2022, 11:53 AM   #42
ZL1Atlanta
ZL1Atlanta's Avatar
Yeah you might need a little more than that. We are at about ~70% utilized on my Fore Triple which is 3 - 125 gph pumps. I am running 100% Ignite red as well.
