Old 02-09-2024, 12:56 AM   #29
Sykotk
Drives: 2024 Riptide Blue Metallic 2SS Conv
Good to know that the Morimotos fit a 2024. I sold my mosaic black ghosted and could kick myself. Is anyone doing the ghosted ones anymore? RPI is a nope and it looks like Phastek isn't offering them anymore either. I'd love to get paint matching ones.
Sykotk is offline   Reply With Quote
Old 02-09-2024, 09:39 PM   #30
havelegs
havelegs's Avatar
Drives: 24 LT1 M
There shouldn't be any change from the 16 MY to the 24.
24 LT1 M6 Sharkskin Metallic
22 Mazda CX-30
havelegs is offline   Reply With Quote
Old 02-12-2024, 05:54 PM   #31
bandier
Got mine!
bandier's Avatar
Drives: 2021 LT1 RS - Orange Crush
Cool. So I dont have to remove the tires or jack up the car? I didn't get to install last weekend as the superbowl got in the way. Thanks for the install tips!
Originally Posted by E75 View Post
Yeah. The little wires have to get coiled up in the housing. But you have to twist the bulb holder in… so it helps to twist the wire the “wrong” way first before you tighten the bulb socket.
Also the rears use a small torx bit on a 1/4 ratchet. No jacking needed to get the fender liner screw out.
On the front there is a little black air duct, you can poke your finger in and release the side marker without any removal of the liner.
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
bandier is offline   Reply With Quote
Old 02-18-2024, 07:45 PM   #32
Summit20171SS
Summit20171SS's Avatar
Drives: 2017 1SS M6
Im thinking about getting a set myself, just torn between the morimotos and the diode dynamics
2017 1SS M6
~ Air Raid Cold Air Intake~ ~ 3" Corsa Extreme Catback Exhaust ~
Summit20171SS is offline   Reply With Quote
Old 02-18-2024, 10:11 PM   #33
havelegs
havelegs's Avatar
Drives: 24 LT1 M
You can turn the front wheels to each side to gain more room. For the rears you can jack up each side to get some room for torx bit/socket, depending on your tools.
22 Mazda CX-30
