Old 04-16-2022, 02:18 AM   #29
sr71bb
sr71bb's Avatar
Drives: 2019 Camaro Z-28
Originally Posted by Eric10905 View Post
It’s going to be a beast. Hope I bump into you at a track day so I can see this build in person. Congrats!
Thanks!! We are coming to COTA with the CHIN TRACK DAYS group later on in year Hope to see you there.
2019 SS 1LE BIG NA A10
Eagles Canyon Raceway 2.7 CCW Below
https://youtu.be/c9M5UHDftcA
4-15-23 at SCCA TT U1 Class
MEGA Thread on THIS car:
https://www.camaro6.com/forums/showthread.php?t=602092
Retired Cars BELOW:
1973 Camaro, 1969 Camaro, 1969 Camaro SS RS
2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10
sr71bb is offline   Reply With Quote
Old 04-23-2022, 08:16 AM   #30
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
How did it turn out?
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 04-23-2022, 09:29 AM   #31
sr71bb
sr71bb's Avatar
Well they got super busy as usual and the head cam install got pushed back to next week. They did send the heads out to get them milled .030 so that compression will be 13:1
Retired Cars BELOW:
Old 04-25-2022, 02:46 PM   #32
pierrotss
Drives: Chevy Camaro SS 2019 convertible
Thanks, I just got a SS 2019 and I'm looking to improve both the car and as a driver. Your posts is a treasure trove.
pierrotss is offline   Reply With Quote
Old 04-26-2022, 04:19 PM   #33
Corbs09
Drives: Chevy Camaro ZLE
Was this car out at the SCCA Time Trial at ECR? I am pretty sure I saw this and parked close by.
Corbs09 is offline   Reply With Quote
Old 04-26-2022, 04:29 PM   #34
sr71bb
sr71bb's Avatar
YEP I was there but I didnt run Time Trial just the regular track day stuff because I wasnt able to attend sunday's portion due to a family event. My tire trailer was parked right next to my car.
Retired Cars BELOW:
Old 04-26-2022, 05:18 PM   #35
Corbs09
Very cool, I was in the white zl1 parked on the other side of your tire trailer. Was my first time at the track.
Old 04-27-2022, 02:11 PM   #36
nasbagoat
Drives: 17 SW 1LE
How is the fitment on your track wheels on the front?
APEX EC-7 18 x 11 ET22 wheels (4) with Pirelli Slicks 305 660 18 (track set up)
nasbagoat is offline   Reply With Quote
Old 04-27-2022, 02:20 PM   #37
sr71bb
sr71bb's Avatar
On the front it is fine with a 5MM spacer when I run the pirelli slicks.. I also run AZENIS RT660 (TW200) tire size 315 30 18 and with those I am going to try a 15MM spacer because I am getting a little rub with the tire on the inside on the strut itself on the fronts using the 5MM spacer. Probably best to stay with 305 width on front. I am test fitting all of that now
Retired Cars BELOW:
Old 04-27-2022, 09:36 PM   #38
sr71bb
sr71bb's Avatar
Update on Engine Work
Well at the SCCA Track Day and TIME trial last weekend I basically blew the engine up (lol). So basically we wont be putting a CAM and HEADS on THIS engine. I broke the TWO adjacent Rods in back of the engine.
For those unfamiliar, the rods get the most force or stress on them when the car is De-Accelerating. There is a stretching force on the rods and over a period of time and this can weaken the rod. So forged rods and rotating assembly are desirable even if the engine produces just a moderate amount of power. What aggravates the situation is the constant high revving range that can occur when using an A10 tranny in TRACK or SPORT mode. The engine RARELY sees less than 4500 RPM even in the tightest of corners.
This happened in the first lap in the first session last weekend. Fortunately I pulled the car immediately off the track and no oil was spilled on the track surface.
So in order to make lemonade out of lemons, it gave me the excuse to go ahead and get an LME 416 with forged rotating assembly with ARP studs, 13:1 compression yada yada yada
Should have that engine installed NEXT week. I will post up POWER numbers at that time.
Retired Cars BELOW:
Old 04-28-2022, 06:13 AM   #39
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
Bummer to hear with the motor! I looked at my data and my average RPM around the track is 5100 with an M6. It's so hard to leave my stock, but the warranty is too nice to have right now and if I modify the motor, I think the way to go is exactly what you are doing.
Ken
khcoaching is offline   Reply With Quote
Old 04-29-2022, 05:55 AM   #40
sr71bb
sr71bb's Avatar
OK a little update on using on the RT660 setup. I just test fitted the 315 30 18 RT660's on the front again using a CAL CUSTOM spacer part number CAL-202375. This spacer is 6.35MM thick. This pushes the tire enough away from the strut body that there is NOT any tire rub on the strut body. BUT, there is maybe just two pieces of paper clearance (1/16th of an inch) room between the tire and the strut body. Remember I am using APEX EC-7 18 x 11 wheels with ET25 offset. i also run about -3.6 degrees negative camber.
So I will try next an 8MM spacer setup and check the tire poke situation out. The RT660s DONT come in a 305 30 18 size which would be perfect using just the original 5MM spacer.
Retired Cars BELOW:
Old 04-29-2022, 07:16 AM   #41
UberMeister178
UberMeister178's Avatar
Drives: 2016 Camaro SS
Found this thread recently and have been following. Huge bummer about the motor. I've got a 2016 SS with very similar suspension and brake mods. My main concern has been long term motor reliability. I only have 23k miles, but was already looking at a Katech or Vengeance Racing NA build with a focus on strength instead of power. Looking forward to reading about your experience with the Katech solution.
Do your seat belts do the ratchet lock trick? My driver's side does not.
UberMeister178 is offline   Reply With Quote
Old 04-29-2022, 08:30 AM   #42
sr71bb
sr71bb's Avatar
Well yes they do. I am not bummed out about the motor at all really. I push the car VERY VERY hard and I knew it was just a matter of time before something let loose on the engine side. The PREVIOUS motor I lost was due to a valve spring breaking which is not an uncommon problem as noted by the fact that GM had a factory recall on some of the LT1 powered cars to replace the valve springs.
I fully expected that THIS motor had also BROKEN some valve springs as well but we found that I broke the back TWO rods in the motor (#7 and #8 hole). The failure was catastrophic needless to say. The LT1 uses a non-forged rod so perhaps if I had a ZL1 with forged rotating assembly, the rods would have survived. Anyway the replacement LME 416 engine will be many times stronger than the LT1 or LT4 is so I should be good to go. I specified ARP rod bolts and studs. Power on an ENGINE dyno should be about 700HP according to Brian at LME.
AMP (www.advancedmodernperformance.com) is actually the one that is doing the NA build on my car and they exclusively use LME (www.latemodelengines.com) as their engine supplier.
Retired Cars BELOW:
