Old 01-01-2022, 08:21 AM   #29
CamOnlyJabroni
CamOnlyJabroni's Avatar
Drives: 19’ ZL1 A10 / 16’ C7Z M7
Saw your ad, decide to screw it and go bigger blower? Or just paying a core charge
I bought the Kong ported blower used and had it shipped to me in a Kong box I had shipped to the seller. That ad is for my factory blower I pulled off.
CamOnlyJabroni is offline   Reply With Quote
Old 01-01-2022, 08:36 AM   #30
Evansa22
Evansa22's Avatar
Drives: 2018 HBM ZLE
Nice, I'm sure that saved a nice chunk especially after you sell yours. Good luck with the rest of the mods, should be quick
Old 01-01-2022, 08:44 AM   #31
CamOnlyJabroni
When it’s all said I’m done blower wise I will have saved $4-500. Thanks and Happy New Year.
Old 01-01-2022, 09:27 AM   #32
laynlo15
Drives: 2022 Lt1 A10
Installing a cam was originally the go to method on these cars to get more fuel and gain another 50-70whp. This ideology was used before there was more affordable fueling options. It's also a great way to make more power without spinning the stock supercharger harder. However things have evolved over the years and again we now have cheaper fueling options along with larger superchargers and improved port programs for the stock supercharger to increase efficiency.
For example...look up airtroops thread on his basically stock motor LT4 CTS-V3. With a 2650 swap and ToohighPsi port injection plates the car made over 800whp on E85. That is with stock heads, cam, exhaust down to the cats.
You can get LPE DI pump and +30 injectors for around 3,740.00. Or you can get Mikes Port Injection plate system for around 2k. Both of those options are cheaper then paying somebody to pull the engine to swap a cam. The LPE +30 combo is going to max around 700whp on full E, probably 750ish with E50 with a bolt-on LT4.... Mike's PI plate system will go 800whp + before needing to address some other areas of the build but the fueling is there for 1k whp. Changing injectors and high side is much more simplistic but obviously more limited. Swapping a cam is going to run 5-6k(unless doing the work yourself) and you will make about 700-730whp on 93. Maybe 750whp with E30 mixed in. So a little more power then the LPE +30 bolt-on combo but nothing drastic. I bet the LPE +30 combo on E50+ runs more consistent being it will be able to tolerate much higher MAT without pulling timing.
Either way the OP already has a 11:1 H/C 2650 C7Z making too much power for the street. He wants this build to be similar to my car. Make just enough power to still be useable on the street from a second gear launch. This should do the trick...It should be a low 10's mid upper 13x combo on 20" wheels. Full drag pack at the track with passenger seat pulled it should have enough to break into the 9's....plenty for a street car.
Those from AirTrooper are some real good numbers.
Old 05-04-2022, 09:24 PM   #33
CamOnlyJabroni
Should have dyno numbers this weekend for the ZL1 and ZO6 both. Only difference is I ended up going with the 2.175 pulley and sold the 2.30/2.50 that came with the blower.
Old 05-05-2022, 08:07 PM   #34
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Final tune revision. Looks like it will handle E60.
Old 05-05-2022, 09:26 PM   #35
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Nice, im out of fuel at 850rwhp, 22d timing and e40.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 05-06-2022, 08:05 AM   #36
CamOnlyJabroni
How much boost is your car showing? 15?
Old 05-06-2022, 09:34 AM   #37
6spdhyperblue
Drives: 2SS 1LE
My e85 pump ends up e60 so that would be perfect.
Do you have to factor in the DA for that limit?
Old 05-06-2022, 10:25 AM   #38
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Right about 15 max. Has the 90mm with a 9.06 lower.
Low side is fine. High side is tapped.
Old 05-06-2022, 10:26 AM   #39
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
Colder weather you usually can’t run as much ethanol.
Old 05-06-2022, 12:19 PM   #40
Evansa22
Evansa22's Avatar
Definitely second this, colder air, more boost, more fuel needed. Had to drop from about e30-35 to e20 to stay safe in cold weather.
Have any plans to go injectors and pump next? Or just straight to your big boy build?
Old 05-06-2022, 03:24 PM   #41
CamOnlyJabroni
When we were out logging it was 55 degress. Not sure what the DA was.
Old 05-07-2022, 07:05 PM   #42
CamOnlyJabroni
Car ended up doing right what I thought it would. Since it was a newer mustang dyno “md-500-se-xl” I was hoping for 720-730. Ended up doing 725/700. Thanks to my bro for the killer tune!
https://youtu.be/HGKoYvGUfL4
