Old 12-05-2021, 01:47 PM   #29
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
Originally Posted by hawk02 View Post
You can all call me crazy, but I noticed a subtle improvement in my car's performance immediately upon changing to the 0W 40 weight oil. My car had a bit more pep and smoother acceleration.
https://www.mobil.com/en/lubricants/...il-1-fs-0w-40/
https://www.mobil.com/en/lubricants/...mobil-1-5w-30/
You can see the differences are minor, 0W-40 is slightly higher viscosity so it may use less oil, especially a higher mileage engine. Hopefully you have a catch can installed because gas dilution trashes oil viscosity quickly
From what I understand the oil pump failures are all because the oil pump gear is cheap pot metal and gets stress cracks, then fails completely over time. A slightly higher oil viscosity would not help
ZX-10R is offline   Reply With Quote
Old 12-06-2021, 10:27 AM   #30
Mark R
Drives: 2018 ZL-1
At the risk of being mocked, I opened up the old oil pump, and it was perfect on the inside. No stress cracks or anything amiss.
I'm really happy I did it anyway. I have a couple of trips planned for next year, and this really takes away any doubts about the reliability of the car.
Old 12-06-2021, 01:20 PM   #31
ZX-10R
ZX-10R's Avatar
How about a few pictures of the gear, etc?
Old 12-06-2021, 04:35 PM   #32
Mark R
Drives: 2018 ZL-1
Here you go. The internal rotor seems like pretty high quality material. It does not look like it would break.
Old 12-06-2021, 04:43 PM   #33
ZX-10R
ZX-10R's Avatar
Thanks - and agree, who would have thought GM oil pumps, especially in this engine, would fail?
Old 12-06-2021, 05:45 PM   #34
ZL1plumbin
Drives: ZL1 1LE on order
Is that the stock one or the Katech unit?
ZL1plumbin is offline   Reply With Quote
Old 12-07-2021, 10:36 AM   #35
Mark R
Drives: 2018 ZL-1
Stock.
Old 12-07-2021, 12:41 PM   #36
Choda
Drives: Turbo 6.2
I upgraded to the TRUCK Katech pump because it was supposed to have higher PSI.
Did any of you change anything in your Tunes after installing the Katech pump?
My oil pressure seems a bit funky to me in all my logs. My main bearings have additional clearance and I also feed the turbo at the same port where the oil pressure sensor is. I modified the valley cover to work with my build. Seems to max out around 50psi. Looking at my old logs with the oem bearings and oem pump but same turbo feed, max oil psi was 55 psi.
2016 Twin Turbo Camaro SS - 968hp/970tq 8.9@153
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100
Choda is offline   Reply With Quote
Old 12-08-2021, 02:20 PM   #37
ZX-10R
ZX-10R's Avatar
Higher pressure for the sake of higher pressure isn't a good idea, you want to run their pump actually designed for the LT4 wet sump engine
https://shop.katechengines.com/produ...sump-oil-pump/
