Old 12-10-2021, 02:15 PM   #29
ZPirate
ZPirate's Avatar
Originally Posted by Alpha1BC View Post
Your dealer is mistaken, you definitely can order them outside of CA/WA; they're just a $500 option as opposed to being standard content. Friend of mine in MI just ordered and got his delivered with them and dealers all over the US are ordering them configured like that to put on their lots.
I guess I need to follow up with him about the copper free brakes again before he submits the order. He is wasn't able to place the order today since he currently doesn't have an allocation.
Old 12-10-2021, 02:18 PM   #30
cdb95z28
cdb95z28's Avatar
I also ordered mine with the copper free, I'm in PA. I got a friend in Michigan too that ordered them with his. Alpha1BC, He might be the same person, haha.
When we did mine earlier in November, we used the Quick Order system as the normal order system wanted to kick it out. A big thanks to GearheadSS for the info on that!
"KEEP THE FAITH"-Fbodfather
Old 01-08-2022, 04:19 AM   #31
Blackmonba6Gen
BLUPRINT_1LE
Blackmonba6Gen's Avatar
Drives: 2022 Rapid Blue SS 1LE
You’ll are spot on. I asked about the difference from a guy who works on the brakes team for GM.
The BCD are 398mm front rotor, new bespoke caliper, zl1 rear calipers, new rear rotor. New pads. He got them on his 1SS 1LE.
i wish I knew about them i would’ve got them but you really can’t tell the difference at face value unless parked side by side. Great bang for buck tho!
2022 Camaro SS 1LE | PDR | Rapid Blue | Manual | Katech Built SS 1LE | Katech Build Sheet
IG: BLUPRINT_1LE
YT: BLUPRINT_1LE
Blackmonba6Gen is offline   Reply With Quote
Old 02-05-2022, 09:41 PM   #32
mRahmani
Drives: ‘23 SS 1LE
Do you guys have any additional info you can share on this? I’m trying to order an SS 1LE with the BCD package here in Michigan and my dealer says the system is spitting it back out. We tried 1SS, 2SS, both with and without 1LE… no dice. Trying to figure out what to try next.
mRahmani is offline   Reply With Quote
Old 02-06-2022, 11:35 AM   #33
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro 1SS 1LE
Why is copper free something to be desired? I get the environmental impact of brake dust, but this comes at the cost of lower pad lining friction. If I were ordering today I’d skip this option. What appeal do you guys see?
5.M0NSTER is offline   Reply With Quote
Old 02-06-2022, 11:55 AM   #34
ZL1C7
ZL1C7's Avatar
Drives: 2023 SS 1LE 10SPD
California banned Camaro's with the copper brake pads. Other states may follow the trend.
ZL1C7 is offline   Reply With Quote
Old 02-06-2022, 01:39 PM   #35
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
& Washington so far
RUQWIKR is offline   Reply With Quote
Old 02-06-2022, 02:16 PM   #36
LateBrakeU2
Drives: 15 RH Z/28, 23LT1VOM
For 500.00 you could be one of very few folks that have a significant line built upgrade to your car if they discontinue the option.
LateBrakeU2 is offline   Reply With Quote
Old 02-06-2022, 02:17 PM   #37
mRahmani
Drives: ‘23 SS 1LE
What makes the option interesting is GM only developed one set of brakes for V8 cars to meet the copper free spec - one that could keep up with the ZLE. The copper free brake package has 15.6” rotors (possibly 15.8”?) and CT5V Blackwing calipers, making it a substantial upgrade on the SS cars. I figure the aftermarket will start providing higher performance pads for them too.
Old 02-06-2022, 07:41 PM   #38
cdb95z28
cdb95z28's Avatar
The copper free brakes on an SS 1LE are a 398mm rotor and bigger caliper. Beyond the copper free pads, those two parts are an upgrade vs the normal bakes on the SS 1LE. And for only $500 more.
Old 02-06-2022, 07:43 PM   #39
cdb95z28
cdb95z28's Avatar
And to answer mRahmani's question,
The dealer will have to use the Quick Order system. The normal order system causes it to reject it.
My dealer used the Quick Order and it worked. My BCD SS 1LE has been built and should be here by the end of the month.
Old 02-06-2022, 10:49 PM   #40
MatthewAMEL
MatthewAMEL's Avatar
The 'copper free' part is the pad. If you swap to a Hawk or other aftermarket pad, you have all the benefit of a larger rotor and caliper.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 02-07-2022, 11:51 AM   #41
shippingguy
Drives: 2024 Black ZL1, M6
You get the larger rotors and the ZL1 calipers. I took delivery of my 1LE here in CA in Nov. love the brakes and the larger rotors!
shippingguy is offline   Reply With Quote
Old 02-07-2022, 05:31 PM   #42
RUQWIKR
RUQWIKR's Avatar
Drives: 1LEs
Multiple threads going on the subject. I posted pics of the pads, etc. in this thread:
https://www.camaro6.com/forums/showt...9#post11129999
