#29 | |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2018
#30 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro Z-28 Join Date: Jul 2010
The real test will be at EAGLES Canyon THIS sunday. I will be running with the CHIN TRACK DAYS group. This track has a half mile straight leading into a fairly sharp left hand turn. I think I will put on the slicks for this one. With the last combo I ran a best around 2.06 but with now a 100 more horsepower I am hoping for something in the 2.02 - 2.03 area. What I have noticed is that because I am NA, the power curve is VERY smooth with this car which helps in NOT unsettling the car as it transitions from mid corner full throttle on to the straights.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 |
#31 | ||
![]() Drives: Chevy Camaro SS Join Date: Nov 2019
2017 1SS:Hi-Ram, FBO, OTR ram air, Circle D converter. Previous PB: 11.07 @124 1/4 7.1 @100 1/8 1.6 60’ w/2” longtubes, 95mm hi-ram, OTR ramair, flex fuel |
#32 | |
#33 |
So I proved you wrong with I’m assuming the video you posted, Because there’s only one video from GPI doing a test like that and it shows/Ryan even says the numbers from each intake manifold. 455 untouched lt2, 458 untouched msd, that looks like a gain to me and knowing that each dyno reads different that means the gain could be more on another dyno. Now port both, and that msd is going to show a decent gain. Now you want to call me stupid when you have a 416 that doesn’t make 600rw, when a 416 with 14:1 should clear 600 all day as long as long as the cam is spec’d for the 416. That 416 makes that NFC look/act small, it “eats” up the duration and causes the cam to act even more mild than it already is.
2017 1SS:Hi-Ram, FBO, OTR ram air, Circle D converter. Previous PB: 11.07 @124 1/4 7.1 @100 1/8 1.6 60’ w/2” longtubes, 95mm hi-ram, OTR ramair, flex fuel Last edited by 17camaroSS; 06-08-2022 at 10:30 PM. |
#34 | |
Bottom line is nobody gives a shit about what either of us THINKS, there is much more value in posting what we KNOW.
2019 SS 1LE BIG NA A10 Eagles Canyon Raceway 2.7 CCW Below https://youtu.be/c9M5UHDftcA 4-15-23 at SCCA TT U1 Class MEGA Thread on THIS car: https://www.camaro6.com/forums/showthread.php?t=602092 Retired Cars BELOW: 1973 Camaro, 1969 Camaro, 1969 Camaro SS RS 2010 Camaro SS with 1000HP F1R, 2019 ZL1 1LE A10 Last edited by sr71bb; 06-09-2022 at 06:58 AM. |
