#29 |
![]() Drives: 2023 2SS 1LE Join Date: Jun 2023
Considered flipping the bracket over, but believe it would then be too tall for the hood.
#30 |
Ok, flipped bracket and BARELY clears, but no longer pushing on that tube beneath it. believe the headliner is touching the top most part of the CC now, but might be just barely (put flour on top most part and some on headliner after closing gently and opening). Better, but not sure about headliner being in contact with it while driving is a good idea. Matt
#31 |
So just a heads up for folks. Not sure if my 23 2SS 1LE is different from others or what, but the bracket that was supplied to me (you can see in the pics above) is not ideal for the E2 CC fitting well. It either pushes down on that plastic tube too much imho, or results in the top of the CC contacting the hood liner. The hood still shuts without issue, but I don't believe touching the liner is good.
So if you order, you might want to talk to someone about the front mount. I ordered mine online without any communication. I'm working with Elite now about fixing this, hoping to get the front mount and hardware sent. Matt |
#32 | |
![]() ![]() ![]() ![]() ![]() Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
#33 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro Join Date: Nov 2009
On the 2023, I do think our 62L bracket might be the best option for mounting.
#34 | |
![]() Drives: 2020 Camaro 2SS .. chevy silverado Join Date: Nov 2019
when i bought it i also ordered an extra bracket 62L thats for mounting it in front Bought Stainless steel bolts 1inch , 1 1/4 and . 1 1/2 with 17 mm head the inch and a quarter worked best for me put a thick rubber o ring (dont remember the size) between the engine and bracket on the otherside of the bracket a internal tooth lock washer then a thin washer by the bolt head.... I tried a internal tooth lock washer on both sides and also tried rubber o rings on both sides ... this seems to work best for me . I'm a Paranoid guy and didnt like how close the bottom of the catch can was to the cooling lines so i cut a rubber heater hose or maybe alittle smaller and put it over the aluminum cooler line attached it with zip ties .. in case the can bracket sags and the bottom of the can touches it ,,, but thats me ..... hope this helps Last edited by PhotoGuy; 09-25-2023 at 06:17 PM. |
#35 |
Wow, thanks for the feedback!! Super helpful Photoguy! Really appreciate it.
The mount is pretty think and good quality, so no way I can bend it. Elite is working with me very nicely on this, even over the weekend and on a Sunday--so very impressed with their customer service. I do think the 62L mount in front is the way to go for our cars. Matt |
#36 |
Yes, that is very helpful. That looks like a 10mm hex bolt x 30 mm long
#37 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS 6spd Join Date: Jan 2011
Yes, nice write up Photoguy especially with the pics.
I've always preferred the Elite CC and it's my belief that a front mounted CC catches more of the condensation (water) that is a normal byproduct of combustion. When the CC is in front of the engine, it catches more cool air and that attracts and holds the condensation. Be aware that the CC may need to be emptied more often in colder weather. Especially if running FI.
#38 |
#39 |
#40 | |
![]() Drives: 2011 GMC Sierra 1500 Join Date: Jun 2022
CLICK HERE FOR INSTALL POST
2023 LT1 M6 Coupe - Black (GBA) on Black (H1T) - Build Date: 8/22
Blade spoiler (5ZU), Recaro seats (AQJ), Technology pack (Y3W) LT1 PBC engine - Shane Parker Current mileage: 400 Last edited by Junction65; 09-26-2023 at 10:43 AM. |
#41 |
Junction--nice option, glad that worked for you and happy to know moving that line is doable. One of the reasons I decided to go with Elite was the feedback on here and the idea that it was a very simple bolt on and engineered to be installed without having to move anything--just put the product together and install. Having to move any line is not something I want to do--again, why I paid a few hundred versus $100 or so.
Having said that, very happy with Elite's customer service and willingness to make it right (in my eyes) in a friendly, cooperative way. Their response was VERY quick and felt like they are very interested in having happy customers. Which is refreshing. So continue to be happy. I wish I had called and spoken to someone about options prior to ordering online like others have done and/or have asked for front bracket. Also just an fyi to anyone looking into this for their car. If you are happy moving a line, the 'normal' bracket might be fine. If you'd like to not have to deal with that, it looks like requesting the front bracket (62L) is the way to go. If I could do it over again, I would 100% chose the front bracket from the get go. Matt |
#42 | |
I simply put the Elite Engineering E2 can for the 2016+ Camaro with the Single Exit port kit together and installed, nothing more.
Blade spoiler (5ZU), Recaro seats (AQJ), Technology pack (Y3W) LT1 PBC engine - Shane Parker Current mileage: 400 Last edited by Junction65; 09-26-2023 at 12:27 PM. |
