09-22-2021, 01:54 PM | #29 |
Drives: 2021 Camaro LT1 Join Date: Oct 2020
yep, these guys for good pricing on oil and filter
https://www.rockauto.com/ |
09-22-2021, 02:05 PM | #30 |
i do 2 oil changes a year but i barely drive 3000-5000 miles a year mostly just driving to the track and back ill have to actually keep track this year...
09-22-2021, 02:12 PM | #31 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
Without screwing around, I think there was a thread back then that touched the subject on the 1-year oil change rule. I held the opinion that you should change the oil yearly, but after seeing the test from Project Farm someone posted in the thread, I have my doubts. I personally would probably still do it just to keep OLM working, though it's not an issue for me since I DD my car and track it from time to time. I also now see why it makes sense for someone to go beyond the 1-year mark if their oil only has low miles on it. I followed the 3k miles rule on my RX-8 since I ran conventional oil in it and it is generally more sensitive to engine oil quality than a piston engine. With my Camaro past the break-in period, I will stick with OLM showing me less than 30% life and when it works for me to change the oil, given that my car has some track miles on it. Even then, that's about 4.5~5k miles between changes.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
09-23-2021, 05:08 PM | #32 | |
Drives: 2017 Camaro SS Join Date: Jun 2021
https://www.mishimoto.com/chevrolet-...hoCpq8QAvD_BwE This is the one I run. Mishimoto. Love it. No issues. Just make sure you check it every 1000 miles for the first oil change. That way you can gauge how full it gets. Shouldnt get full that fast. But always nice to check. Should drain every oil change from that point after. Also again. Don’t worry about it the 5900 mile thing. These motors come with cams that have already been broken in by chevy. So even if he drove it hard. It’s fine. Its made to be driven hard. My advice? Establish some reliability in it. Drive it hard as hell for a few days and let it show you what it’s made of. You will be impressed at just how mush these lt1’s can take. |
09-24-2021, 06:26 PM | #33 | |
Drives: like an old lady Join Date: Jun 2012
what does chevrolet do to "break in" a hydraulic roller camshaft? also - the LT1 engines are internally identical to those offered in some pickup trucks and large SUVs. are those trucks and SUVs also built to be driven hard and/or abused? the 6.2 is only offered in the highest trim lines, certainly not work trucks.
09-28-2021, 07:54 PM | #34 | |
Drives: 18 2SS 1LE NFG Join Date: Aug 2018
09-29-2021, 03:37 PM | #35 |
Sorry, let me explain that better. I don’t mean they take your motor and run it to break it in before you receive your car. I mean the break in period has been engineered out. Our cams don’t require a break in period. Roller lifters are used in our lt1’s which means they don’t have to seat like old style camshafts. Mix that with tight bearing clearances and low weight thinner oil for less friction, you get a motor that doesn’t require a break in period. I’m just a guy on the internet so Google can prove it better than I can. But the only thing most people recommend actually is to drive it hard so that the rings seat to the piston. Rings seat under high combustion chamber pressure. Aka, floor it. In other words, your fine.
09-30-2021, 12:40 AM | #36 |
youre in trouble if the rings are seating to the piston.
10-01-2021, 03:10 AM | #37 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
And, if you don't think a freshly built motor doesn't need any break in you're in trouble.
10-01-2021, 07:12 PM | #38 |
ring seat & a few heat cycles. what's left to "break in"?
10-04-2021, 10:46 AM | #39 |
Drives: 2018 Camaro 1SS 1LE Join Date: Jun 2018
To answer OP: Only issue seems to be the oil pump and the AFM lifters with hard use. Other than that they are pretty stout cars. I have heard of a few valves dropping but not enough that I was ever concerned. Usually caused by another valve train issue listed above or user error.
As for break in, all cars need a break in period. Our manuals call for it and any engine builder will require some method used. I was told the break in procedure by my dealership and GM even puts a different gauge clusters to show a lower redline early on in ownership for vettes which have the same LT1 motor. I'll agree the camshaft is probably less important and takes less time to break in than piston rings now a days. We know exactly how much GM test cars before shipping them because it is usually the mileage on the car before you receive it and by testing I mean shipping and receiving moving it around.
10-18-2021, 09:56 PM | #40 |
Drives: 2020 LT1 Join Date: Dec 2019
My break in consisted of beating the balls off it as long as it was up to temp from day 1. At 3000 miles, doing cam and full bolt ons on E. Dumping the clutch at 5k on slicks 30+ times. Its a pushrod V8....some over think things. You dont need to be delicate, its a Chevy. Not a vintage Ferrari
10-21-2021, 04:09 PM | #41 |
Drives: '16 2SS M6 Join Date: Aug 2019
I'm at 84K on this car, wrecked my first one at 80K. Both run/ran like new. I changed my oil at 15K miles with Mobile1 extended performance due to how fast I was putting on the miles. Used to have a 270mile commute before Covid. Now I work close to home and change it when the reminder comes on, which is 7500. And no catch can on either one of them.
David
'16 2SS M6 black on black, SW long tube full exhaust, NPP, Roto-fab CAI, ported stock TB '16 2SS M6 black w/Metallic black stripes, Kalahari, 6 piston front (totaled 1/22/20) '14 Fusion Titanium 2.0T '83 Jeep Wagoneer |
