#29 |
The Rotofab Dry is worth a real 5 RWHP. Plus it sounds great. I do not think just changing thr filter will do anything.
But I have read you can get about the same hacking up the stock box. It actually flows pretty well for stock. GM did not leave much room to grow in the tune or with intake flow for us to fool with.
#30 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 LT1 10 speed auto Join Date: May 2013
I already removed baffles inside the stock box and opened up the front of the box down low to pull in cool air just below the factory opening. Maybe by adding a high flow filter element it may complement that mod, Thanks Fraxum.
#31 |
Careful. Things like baffles, shape of openings, and turning vanes may be there to prevent turbulence and encourage laminar flow.
#32 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
this is 100% true. i cut just the triangle portion, facing the front of the car, out of the lower air box and my car lost 6 mph. completely stock at the time.
#33 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Camaro 2SS Hyper Blue Metallic Join Date: May 2020
#34 | |
#35 | |
![]() ![]() ![]() Last edited by jamala00; 09-20-2021 at 01:13 PM. |
#36 |
![]() Drives: 22 Camaro 2SS, 20 Subaru Crosstrek Join Date: Aug 2021
That is referring to there not being a need for the tower-to-tower brace, which they still sell as an add-on option. The braces that were removed and should not have been are the "rearward-facing v-braces" mentioned about halfway through that comment.
Earth is an oblate spheroid
2022 | 2SS | M6 | NPP | Summit White | Carbon Flash Wheels | Black Lugs | Red Calipers | Adrenaline Red | Red Knee Pads | Nav | - 1100 - 8/16/21 - 3000 - 9/21/21 - TPW 10/18/21 - 3400 - 10/1/21 - 3800 - 10/20/21 - built 10/19/21 - 5000 - 11/12/21 - 6000 - 11/13/21 |
#37 | |
#38 |
![]() ![]() ![]() Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
I've never really looked into it, but there is no way of removing these right? Without cutting of course which I guess is what someone did. It would be nice if you could remove them for easier access to things when working on stuff though especially in the corners of the engine.
