Old 01-14-2025, 06:07 PM   #29
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Originally Posted by bowtie_thunder View Post
I hate ressurecting dead threads to zombie levels as much as the next guy, but what did you use to fit new seals on?
I'm currently using my vehicle as a work project. I recently put together an LT4 fuel system and LT2 intake to get literally the same WHP (but potentially as a max effort N/A build, no PD or centrifugal). I also don't have a GM tool to remove the injectors from the rail, but I'm confident I can get it off with your method. I don't plan on swapping injectors often, so I can't really see myself getting a nigh-$200 tool that I'm only going to perhaps use once. Any tips on this?
I’ve never needed a tool to remove the injectors. However get a good quality seal compression tool for reinstalling them. I bought a cheap Amazon tool the first time around and it sucked lol
Old 01-17-2025, 02:32 PM   #30
ZO6Ted
Old badass
ZO6Ted's Avatar
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2
Anything to do in the tune to start besides change the
flow rate? Put L87 inj on L83 2.9 Whipple because I had them and it's dumping fuel at idle. Replaced seals. Went 96.5>121.1 in Hp. Out of ideas..
I've had 7 Camaro's. All gone...for now.
Current build in progress 2016 GMC4x4 RCSB twin hair dryers ~1k whp fbe port inj 1/8 mi & stealth street terror
ZO6Ted is offline   Reply With Quote
Old 01-17-2025, 07:23 PM   #31
M1nd64m3
M1nd64m3's Avatar
Drives: 2016 camaro ss
I didn’t use the seal tool on mine and it was fine. I did clean up the bores before installing though.
M1nd64m3 is offline   Reply With Quote
Old 01-18-2025, 06:00 PM   #32
ZO6Ted
Old badass
ZO6Ted's Avatar
My apologies to the OP. Just realized I butted in with an off topic question. A few beers and much frustration sir. Best, Ted
