Old 08-11-2021, 07:18 PM   #29
Staves
Drives: women crazy
Originally Posted by Can'tHave2MuchHP View Post
I have big hands/fingers too
‘19 1SS A10, Borla S-type Non-NPP-SOLD
Staves is offline   Reply With Quote
Old 08-11-2021, 09:06 PM   #30
Idaho2018GTPremium
Idaho2018GTPremium's Avatar
Drives: 2021 Camaro ZL1 A10
Originally Posted by Dan82679 View Post
The stock wheels look better than any of the wheels people have posted on here.
I agree. It takes a pretty nice wheel to beat the factory ZL1 wheels in the looks department IMO on the Camaro.
2021 Camaro ZL1 A10
2022 GR Supra 3.0
Past:
2018 Mustang GT Premium w/ PP1, MR, and A10
2007 MazdaSpeed3
1995 Pontiac Trans Am
1987 Camaro Z28
Idaho2018GTPremium is offline   Reply With Quote
Old 08-11-2021, 09:34 PM   #31
Tuner2muscle
Drives: 2019 Camaro ZL1
ZL1 wheels
solution ..... see below
you're welcome
Tuner2muscle is offline   Reply With Quote
Old 08-11-2021, 09:54 PM   #32
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
you're welcome
Should of kept them black IMO.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 08-11-2021, 10:12 PM   #33
gtfoxy
Drives: '21 Wild Cherry ZL1
Sorry, but same.
As to the thread topic I clean mine using eagle1 wheel cleaner with soft paper towels & use the floss method behind the spokes.
I’ve tried dowsing them then spraying them off, but it just doesn’t work as well as getting down there & hand cleaning them.
Old 08-12-2021, 03:32 AM   #34
Z OH 6
Drives: 2024 CT5-V Blackwing
That's certainly YOUR opinion.
Old 08-12-2021, 03:39 AM   #35
Z OH 6
I agree here in my opinion, but everyone has different taste. I debated strongly on swapping my wheels but in the end, I wanted my ZL1 to look like my own, not like everyone else's and that was my main factor. Mine are just as much of a hassle to clean as the stock wheels though.
Old 08-12-2021, 09:17 AM   #36
infinitereality
Limitless Imagination
infinitereality's Avatar
Drives: 2018 ZL1 & 2022 Hayabusa
I dig the above ones, great choice!
IMO while the stock ZL1 wheel is most definitely one of the better looking OEM wheels out there, but you I can always find a better looking aftermarket wheel.......and equally important, a more aggressive offset than stock.
On my old Audi S7 I had 3pc ADV.1s on it. Even though they were a $10k set (wheels only) that looked awesome, I hated cleaning them even worse than the ZL1 wheels (and didn't near as much as I should have). I'll also never own a set for a daily driver, bent 2 lips ($400 a pop for outer lip, bare metal) where as I would have had no damage with regular OEM wheels in same size. Live and learn.
I'm hoping to come across a used set of SS1LE wheels for a great deal eventually so it'll be worthwhile to get them refinished in some shade of gray or maybe silver
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof
- Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED
- RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook
- Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin
2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels
- +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc...
infinitereality is offline   Reply With Quote
Old 08-12-2021, 09:25 AM   #37
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
If you don't track the car then change the brake pads to Power stop Z26 carbon ceramics. You will have more then enough braking power for the street and the wheels will stay soooooo much cleaner and easier to clean.
Old 08-12-2021, 09:46 AM   #38
KMPrenger
KMPrenger's Avatar
The aftermarket wheels that "Z OH 6" is running look great. There are other good options I've seen out there also. Go find what you like and get em! Otherwise (my opinion) I'd choose the stock wheels. Yeah they are busy, but they are nice. That said, I think the best looking wheel for this car is the stock SS 1LE wheels...which is why I'm running a replica set of them in gun-metal gray (with a gloss clear coat) on my SS. They aren't too difficult to clean either. Not a big fan of black wheels; as someone else in this thread said, the details get lost too easily. A glossy grey is still nice and dark, but those details don't get lost.
As for the brake dust, the Brembos on the SS are just as bad. One drive to work and back and my wheels would be covered in brake dust. I don't track the car, so I switched to the Z26 pads that KingLT1 mentioned above. Stops good, and the dust is pretty much gone now. Much better.
Old 08-12-2021, 10:33 AM   #39
Jaxcam02
Jaxcam02's Avatar
Drives: 2017 Silverado/2017 ZL1
Well, I just spent the last few minutes throwing together an excel sheet with the cheapest way to do a powerstop 4-wheel rotor and pad swap. Just sharing is anyone else is looking to reduce dust and save the stocks for the track.
Jaxcam02 is offline   Reply With Quote
Old 08-12-2021, 10:34 AM   #40
ZZorro
Drives: 2022 ZL1 1LE - A10
Yes I would be when both cars show up
ZZorro is offline   Reply With Quote
Old 08-12-2021, 10:50 AM   #41
infinitereality
Amazon not carry the Z26 pads anymore or out of stock? I got mine last week, probably should have shopped around but wanted them here by the weekend. It was right at $130 for all 4 corners
Old 08-12-2021, 10:51 AM   #42
Jaxcam02
Jaxcam02's Avatar
said out of stock atleast by searching by part number
