Go Back   CAMARO6 > CAMARO6.com General Forums > Z/28 Discussions
Old 07-01-2021, 01:42 PM   #29
396ssrat
Drives: 66 Chevelle SS
There are still tens of thousands who buy cars that don't know a new Camaro even exists.
It is the best kept secret in the entire lower case gm lineup.
BUT, in fairness there are a great number of foreign owned companies who sell cars in the USA that I am oblivious to as well. If there isn't a moniker on them I have zero idea what they are because the majority of them don't command a second glance. I don't think the Camaro is a bad looking car, it's just that the lower level Camaro is basically an also ran in appearance. Lower case gm could have easily given the car some nicer exterior trim. Their sales tactics of "Packaging" would cause me to pass on by on certain Camaro models. If I want a car with rally stripes on the hood vs an all black hood I should be able to order the damned thing that way.
66 Chevelle SS 396
91 octane Driver n/a
6.44@105.78 1/8th mile
Old 07-01-2021, 02:00 PM   #30
Bhobbs
Bhobbs's Avatar
Originally Posted by Mountain View Post
The problem with this is durability and cost.
The L8T 6.6L, which is based off the the other LT1/L86/L87/L83/L84 Gen V V8's, is basically a stroked LT1/L86/L87. You add stroke and RPM... you are going the wrong direction for robust high-RPM engine. It can be done, but costs a lot more time and money to carry out.
-Increased relative piston speed.
-Increased frictional losses between the cylinder wall and rings and piston skirts.
-Increased relative stresses on the rods and crank.
You're better off, for where Camaro is currently, taking the LT2 and just adding RPM - new camshafts, modified heads and new valvetrain.
A DOHC, VCT, large-bore, short- or medium-stroke V8 is, really, the way to go for something like a next-gen Z/28 though.
A FPC adds in additional investigation towards the NVH put into the vehicle in respect to driver/passenger experience and also the vibrations into the powertrain/drivetrain attachments (engine mounts, front cradle, exhaust, exhaust mounts, transmission, clutch/converter, transmission mount... all down into the rear diff). All of that was a HUGE deal for Ford with the GT350 and GT350R-C.
The 6.6 has a shorter stroke than the LS7, which had a 7,000 rpm redline. At 3.86” stroke, the 6.6 would be capable of more RPM at the same piston speeds as the LS7. You could get another 300 rpm at 3.86 for the same piston speeds as the 4.0 at 7,000.
Old 07-01-2021, 02:13 PM   #31
Bhobbs
Bhobbs's Avatar
Originally Posted by RLHMARINES View Post
This is supposedly what's upcoming in the Corvette Z06 flat-plane crank V8 engine block without heads. I'll just leave this here for scrutiny.
Where did you find these?
Old 07-01-2021, 02:15 PM   #32
90503
90503's Avatar
Drives: 2011 2SS/RS LS3
I recall a Z/28 for the 6thGen was a non-issue after the ZL1-1LE came out. Remember all the camo-spyshot-videos from the 'Ring back then? If they didn't build, or call it a Z/28 then, I don't see them doing it now.
The ZL1 1LE filled the bill for an all out track car, wouldn't have been a surprise if they had called it Z/28, and made a new Camaro called a Z/28 rather unnecessary. Just my $.02.
Old 07-01-2021, 02:57 PM   #33
Martinjlm
Retired fr GM + SP Global
Martinjlm's Avatar
I totally agree that from a track car perspective, the ZLE made the Z28 a non-starter. Could be that the reason for calling it ZL1 1LE instead of Z28 is the supercharger. Z28 has tended to be an NA track car. But then again, so was ZL1 until it wasn’t.
Old 07-01-2021, 05:25 PM   #34
396ssrat
Valid points.
66 Chevelle SS 396
Old 07-01-2021, 05:34 PM   #35
Xaxas
Xaxas's Avatar
Drives: 2019 2SS 1LE
The problem is that the ZL1 has pretty much all the equipment the Camaro can have and makes it heavier, they should have offered a Z28 variant with only 1 speaker, being able to delete ac, smaller screen, less sound deadening, lighter seats and recalibrating stuff to account for this.
Another reason people want the Z28 is because of how damn good the LS7 was, LT1 and LT4 are amazing, but add an hypothetical LT7 for the Gen 6 Z28 and suddenly you have an extra special model that will appreciate over time since it'll be so limited.
Current: 2019 2SS 1LE aka "Blanc"
Previous: 2017 2LT aka "Noire"
Mods: Chevrolet Performance Suspension || K&N Cold Air Intake || Borla ATAK Mufflers + Catback system || MRR 650 ZL1 replicas with squared 285/30 Michelin Pilot Sport 4S || ZZP 4 piston brake kit + braided brake lines || BMR everything (Solid/Lockout cradle bushing are a MUST in Camaros)
Xaxas is offline   Reply With Quote
Old 07-01-2021, 06:14 PM   #36
Bhobbs
Bhobbs's Avatar
The existence of the GT2RS didn’t stop the GT3RS. The ZL1 1LE should have no bearing on the Z/28. My guess is they knew a Z/28 wasn’t realistic, so the ZLE was the next best thing. In all likelihood, the obesity of the C7 made a naturally aspirated, AFM, automatic friendly n/a engine a tall order. Especially one limited to the lower RPM range of a cam in block V8. That rolled down to the Z/28 not having an engine.
Old 07-01-2021, 08:29 PM   #37
396ssrat
That is old, it has an upper case GM in the casting. Lol
66 Chevelle SS 396
Old 07-01-2021, 10:20 PM   #38
MatthewAMEL
MatthewAMEL's Avatar
[QUOTE=396ssrat;11033826]That is old, it has an upper case GM in the casting. Lol[/]
The LT2 has GM as the casting mark. I have seen no motors with a lower case.
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
Old 07-01-2021, 10:37 PM   #39
Martinjlm
Martinjlm's Avatar
Comparing Porsche portfolio to Chevrolet portfolio is comparing apples to tree nuts. Porsche is a sports car and SUV company playing in the really high dollar range. They slice the bread ridiculously thin. There’s about a dozen models of 911. About 8 or 9 models of Panamera. Chevrolet is a family SUV/truck/sedan company that happens to offer a couple cool sports cars. We’re lucky to get 4 Corvette variants and 6 Camaro versions.
Old 07-01-2021, 10:57 PM   #40
hotlap
hotlap's Avatar
The ZL1 1LE had a slash like the Z/28. Purist didn't want the name used, so they didn't. The suggestion was there.
Ronald Reagan -
Old 07-02-2021, 02:39 AM   #41
The Maverick
Somewhere in the Kalahari
The Maverick's Avatar
Following on the Mach E thing, watch the seventh gen be the E/28...
Old 07-02-2021, 07:40 AM   #42
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
GM. You make it, will send deposit today
Timbo-1LE is offline   Reply With Quote
