Old 05-26-2021, 10:07 AM   #29
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Tuning the transmission doesn't add any power per say...it simply allows all of it to make it to the tires all the time. This equates to faster acceleration. This is part of the reason why all those online power vs weight = 1/4 time calculators don't compute for the newer cars. You need more power then what those calculators show to run the predicted times. They don't factor all of the Torque Reduction and Torque Management that is in play on these higher powered factory cars.
The A10 shifts 5 times before the 1/4 mi and it pulls the timing back to -10 degrees on each shift. The first 2 shifts on a A10 takes like .5 tenths to complete. 4th on is about .25 tenths. The difference between a properly tuned A8/A10 is that a stock one will shift and not gain any ground on the shift, where a tuned one will usually pull soon as it shifts. 2-3 tenths reduction is pretty common and that is still leaving some TR in play. Remove all TR and you will see another tenth drop.
Old 05-26-2021, 10:33 AM   #30
juice3
juice3's Avatar
Drives: 19 ZLE A10,17 SS 1LE, 16 C7R,CT5V
I have mine, got it from HHP Chuck. Going in soon!
juice3 is offline   Reply With Quote
Old 05-26-2021, 11:32 AM   #31
Z OH 6
Drives: 2024 CT5-V Blackwing
On street tires pulling some timing probably isn't a bad thing since it will keep the tires from breaking loose on shifts. On drag radials, probably a different story.
Old 05-26-2021, 11:58 AM   #32
clg82
Drives: 2020 Camaro ZL1
So juice correct me if i'm wrong but after speaking with Chuck at HHP he said it was $800.00 for them to send me a TCM, plus $500.00 for the tune, and that I would ALSO need to purchase HP Tuners in order to add the tune to the TCM that they sent to me...does that sound about right? Seems like a lot of money just for a transmission tune especially if i need to purchase HP Tuners myself just to load their tune.
Old 05-26-2021, 12:59 PM   #33
juice3
juice3's Avatar
That’s business bud
Old 05-26-2021, 01:43 PM   #34
clg82
That’s business bud
I get it man, i was just assuming it would be a tune they could throw on the TCM and send.....I would assume all ZL1s came with the same A10 transmission tune and they could cover all of them, but apparently you need to drive with it first?
Old 05-26-2021, 02:37 PM   #35
Camaro1973
Camaro1973's Avatar
Drives: 2019 ZL1
The prices are fair, your paying for a new tcm, a tune and to unlock the tcm. TCM tunes are unique just like tuning the ecu. Its based on your power etc.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90
Old 05-26-2021, 02:49 PM   #36
JSH
JSH's Avatar
Drives: '20 ZLE
and you need a good laptop, and... credits with HPT and...and...
2020 ZL1LE A10.
100 octane: 1045hp/1055tq.
Old 05-26-2021, 03:27 PM   #37
clg82
Long story short it's a very expensive process that isn't just a mail order tune....it's more involved and more expensive than that.
Old 05-26-2021, 10:14 PM   #38
clg82
Is HHP currently the only vendor offering this?
Old 05-27-2021, 02:21 AM   #39
juice3
juice3's Avatar
Yes
Old 05-27-2021, 08:43 AM   #40
KingLT1
KingLT1's Avatar
Well that is because HHP is the first to come up with a solution to tune 2020+ A10's. So they currently hold all the Market share.
Either way, Welcome to the world of modding newer cars. I waited until I knew we had full access of all controllers before buying my 6th gen. 2016 only requires 3 credits to license all controllers.
Old 05-27-2021, 09:42 AM   #41
JSH
JSH's Avatar
Drives: '20 ZLE
I'm sure I'll buy one and just as sure that I don't know how to tune my A10. Would you repost those images of your TCM tune to give us some ideas about the required tuning?
2020 ZL1LE A10.
Old 05-28-2021, 07:34 AM   #42
gtfoxy
Drives: '21 Wild Cherry ZL1
I get what you are saying.
Had a guy with a 5.3 turbo truck that wanted to cheap out on having his tranny built, but wanted me to dial back the TD. I told him that wasn’t a good idea as it’s probably the only thing holding his tranny together. He didn’t believe so I said fine, I’ll give you one pass at 0%. It wouldn’t even make the shift to 2nd. He looks at me & says OK, turn in back to where it was.
Wasn’t sure if the new stuff was more active through the gears.
