#29 |
USCG Retired (MKC)
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
The car is extremely stable and the frames have a wide footprint, QJ says you can use on a 3% grade safely. I used it on my Tundra with the SUV extensions and it really doesn't lift the truck high enough to be worth the trouble of dragging them out, the trucks ground clearance is so high. Works like a champ on the Camaro and Camry or anything else close to the ground.
#30 |
They have a mechanical safety, so even if the hydraulic lines or any of the powered components fail, the jack will not collapse.
#31 |
2020 Shadow Gray 2SS
They are very safe, there are mechanical stops at 1/2 way up and full up... They have a video on their website of the 5000SLX lifting something like 22,000 lbs...
After delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Pedals, SS Wheel Caps, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF-Full Front & Rockers, 35% Tint, CeramicPro coated, RST Stainless Brake Lines, Castrol SRF, MSD Plug Wires, Mamo V3 Ported TB Left: My "fun" ride (475 HP). Right: My "work" ride (52,000 HP): a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph. BOTH AWESOME to operate... |
#32 |
Faster!!!
Drives: 2020 Camaro 1SS 1LE Join Date: Mar 2020
Very, very safe, I use mine all the time on multiple vehicles. Best investment I ever made for working on vehicles!
#33 |
![]() Drives: 2021 LT1 Join Date: Aug 2020
Check out this video. Shocking!
#34 |
![]() Drives: 2021 Crush ZL1 A10 Join Date: Apr 2017
I have the same garage flooring, what is that pad you have under your QuickJack?
2021 Crush ZL1, "CYNISTR", A10, Black Center Stripe, ZL1 Addons tow hook and lift points, Continental XtremeContact DWS 06 PLUS, XPEL Ceramic window tint.
#35 |
![]() Drives: Camaro ZL1 Join Date: May 2020
I have purchased the 7000slx. Hopefully they fill fit the factory jack point locations. Some have said it would some have said I need the ext version. I did measure it, if my measurements are accurate the slx version should work. I guess trial and error at this point will do, as the package has arrived today. Worst case scenario I either return them or I buy the extension if they do not fit.
#36 | |
With that being said, I did end up buying the extensions and also the ZL1 Addons lift points (which I just installed today), I'm still needing to lift at the aft portion of the rear lift point but I can now lift from the aft portion of the forward of the 2 front lift points, so basically I'm lifting the front about 8" further forward, which should remove any doubt about stability... I'm going to lift it this way for the first time tomorrow to change my oil and diff fluid... I'll try to take pictures if I remember...
#37 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '21 ZLE A10 Join Date: May 2012
I just purchased an open box 7000-SLX from the Quickjack website for $1182. Decided to get the extensions for $249 also. Looking forward to having a lift device in my garage. Great thread!
#38 |
Just set it up now. It’s a bit tight, just have to have the jack pads lined up perfectly. But once you do the factory lift points do work. I got it from Costco for 1,604. With tax and shipping. Also came with the truck lifting accessories and the wall mount.
#39 |
Ok, got the 2SS up on the QuickJack BL-5000SLX (with extensions) today using my new ZL1 Addons Lift Points... I promised pictures, so here you go...
Taken from the passenger side: Rear lift point, passenger side: Forward lift point, passenger side: (the body panel line is where the passenger door meets the front fender) These are from the Drivers side: Forward Lift Point (Drivers side): Aft Lift Point (Drivers side): Using the Extensions on the SLX, I had to put the rubber blocks at the further out points, my ZL1 Addon lift points are about 63.5" on center, the the length of the extensions is 66" so there isn't a lot of margin for error but I am definitely lifting the car much more forward than I did before I had the extensions and before the ZL1 Lift Points (when I was just using the rubber pinch weld blocks). Here is a picture of it lifted WITHOUT the extensions and WITHOUT the ZL1 Addon lift points, you can see how much further back the forward lift point is: And with the extensions:
