#29 |
![]() Drives: 2016 camaro 2ss convertible Join Date: Feb 2021
Update change the temp sensor with a ac Delco. Problem still happened again. Gotta be something in the computer
#30 | |
This has been the culprit for fan problems with some of my previous cars. EDIT: Manual shows K22 Cooling Fan Control Module. Located top rear edge of the fan structure. The fan wiring plugs into this. DIAGNOSTIC INFORMATION AND PROCEDURES > DTC P0480, P0691, OR P0692 (LT1): COOLING FAN SPEED > CIRCUIT/SYSTEM DESCRIPTION The engine cooling fan system is composed of one electric cooling fan and a cooling fan control module. damage in the case of a short circuit condition in the cooling fan motor.The engine control module (ECM) controls the fan speed by sending a pulse width modulated (PWM) signal to the cooling fan control module. The cooling fan control module varies the voltage drop across the cooling fan motor in relation to the pulse width modulated signal, which enables cooling fan operation at variable speeds. The ECM will only operate the cooling fan at certain percentages to prevent undesirable noise and vibration. The cooling fan control module is thermally protected to prevent module Last edited by ctrlz; 03-15-2021 at 09:57 AM. |
#31 |
Update:... it was the thermostat... they sent me a 160°F thermostat. Order a 194°F thermostat hasn't went back into safe mode
#32 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 LT1 10 speed auto Join Date: May 2013
Great to hear and as I predicted was the issue. BTW, each thermostat is marked on the bulb end the temp in celsius not degrees.
