Old 05-08-2021, 06:57 AM   #29
jaybee924
Drives: R.I.P. 2021 ZL1 & 2019 Rd Garn 2SS
Just went out for a drive and the Corsa setup is absolutely amazing. So clean sounding inside the cab. No drone at cruising speeds even with the valves open. Very throaty sounding part throttle and screams bald eagles @ WOT. Close the valves and it's stock NPP quiet.
I would definitely put the Corsa NPP in a nother league above the Flowmaster as it should be for the cost. The Flowmaster is still great for the money but I would suggest spending the extra if you can swing it!!
Sounds great. How do you think it sounds loudness wise vs. a Borla Atak/Sport if you've heard one in person with headers or deletes? I went with a Borla S-type on my ZL1 knowing later I'm going to add cat deletes or headers later. I seen a lot of your build and notice you're going from cat deletes to headers. I know you have a lot of power, how much do you think your going to pickup horsepower wise?
jaybee924 is offline   Reply With Quote
Old 05-08-2021, 08:27 AM   #30
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I haven't heard a Borla in person but If I had to guess the Corsa NPP with resonated x would be similar to the Borla Sport with non resonated X with valves open and a bit quieter with valves closed.
I mainly bought the headers because the catless units seem to be getting harder to get. I figure I'll sit on them for now. I only expect to gain 15-20whp coming from cat deletes.
Old 05-08-2021, 09:32 AM   #31
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I’d suggest you weld in a bung for your wideband into the collector then send them out for ceramic coating before you install them.
Old 05-08-2021, 09:48 AM   #32
KingLT1
KingLT1's Avatar
