Old 02-12-2021, 10:12 AM   #29
6spdhyperblue
Drives: 2SS 1LE
In this car I thought rp synchromax made cold weather op a little notchier. I like it better anyway and will continue using it. Also thought my mpg went down too.
Maybe fresh stock fluid would be the best for cold weather and those that saw improvement even with rp in cold had worn fluid or incorrect fluid level previously?
RP synchromax filled to the full hole ftw
I used mobil 1 in my t56 and hated it. Drained it for pennzoil dex3. Mobil 1 wasn’t cheap
Old 02-12-2021, 07:09 PM   #30
getchapull
TEXIT
getchapull's Avatar
Drives: 2019 ZL1 M6
"RP sucks"
getchapull is offline   Reply With Quote
Old 02-13-2021, 08:28 AM   #31
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
That's what I say from experience!
https://www.camaro6.com/forums/showthread.php?t=569879
Old 02-14-2021, 07:08 AM   #32
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Originally Posted by getchapull View Post
No problems with RP and letting it drain out the fill hole per Tremec instructions. This was over a year ago.
Thanks, I ended up adding a little more till it just oozed out a little.
pauly1119 is offline   Reply With Quote
Old 02-14-2021, 11:37 AM   #33
Big Lebowski
Big Lebowski's Avatar
Drives: 022 C8 Z51 Red Mist HTC
This statement could fit so many different, yet forum inappropriate conversations.
Big Lebowski is offline   Reply With Quote
Old 02-14-2021, 12:13 PM   #34
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Old 02-14-2021, 12:19 PM   #35
2004YZFR1
Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE
Did the dealer do a flush of the system also when they changed the fluid? I would think there is a good amount in the lines and cooler that wouldn’t get exchanged unless it was flushed.
2004YZFR1 is offline   Reply With Quote
Old 06-09-2023, 01:19 PM   #36
Ruthlesszl1
Ruthlesszl1's Avatar
Drives: 20 ZL1 m6
Wondering this as well I want to switch to the tremic fluid but not sure if I need to flush or they can mix a little?
Ruthlesszl1 is offline   Reply With Quote
Old 06-09-2023, 03:07 PM   #37
1sickzl1
1sickzl1's Avatar
Drives: 2022 ZL1 M6
Redline ATF, did it in my garage. You'll need a pump/syringe like you would with the diff fluid. You can use the tranny sensor as the drain plug. It's easier that way since the technical drain plug is hard to reach
2022 Black ZL1 M6
RF intake, Soler TB & TC, ADM v2 reservoir, AWE Touring non-resonated catback exhaust.
535 whp, 537 tq. SAE Smoothing: 5. DynoJet.
No tune. 91 octane.
1sickzl1 is offline   Reply With Quote
Old 06-09-2023, 11:02 PM   #38
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
I don't think you need to drain out the 8oz for normal driving. On the track I get a tablespoon or so dripping from the trans for about 6 sessions after a change. I figured out it is from the vent hole at the top. At the track the temp gets to 200F + the g forces it mists out, condenses, and drips down. Eventually it stops. Street driving you'll never get close to getting the fluid that hot. I had zero drips before the track days.
The Tremec fluid is more of a gear oil spec and is better for track use IMO.
wakespeak is offline   Reply With Quote
Old 06-10-2023, 11:01 AM   #39
AZ_1LE
Drives: 2019 ZL1 1LE
The lines are completely separate and ONLY part of the cooling system for the transmission and differential. You do not need to touch that at all. Only drain the transmission fluid and refill with just under 3 liters (I use Amsoil Signature ATF in my SS 1LE as well as my ZL1 1LE).
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
