Old 02-02-2021, 10:36 PM   #29
20Bluezl1
Originally Posted by Alain View Post
This will be an issue for me. I don’t want to have to take the car somewhere to have something fabricated.
Anybody know if Kooks needs something to be fabricated as well?
I searched left and right and the best I could find while using my suit case was ARH or Kooks. Kooks was more money because of the green cars.
I believe the best bang for the buck is the ARH you just have to deal with the motor mount.
I should have some feedback on the bmr mount installation later next week.
Old 02-02-2021, 10:38 PM   #30
Alain
Alain's Avatar
I always heard that doing headers and keeping the rest of the exhaust stock produced an undesirable exhaust note.
Im looking forward to getting your feedback after install.
2018 ZL1 1LE/Red hot
Old 02-02-2021, 10:59 PM   #31
20Bluezl1
Also the best part is your in NJ you can hear it in person and decide if you like it.
My setup will be ARH headers with there cats and long system into the suitcase
Old 02-03-2021, 07:08 AM   #32
ZLE dude
Drives: '18 ZL1 1LE
I had heard that as well regarding the sound with the cats removed and LT's. But I love the sound of the car and everyone else tells me it sounds great as well so I'm happy with it. I don't ever intend on changing anything past the headers so the CSP setup was exactly what I needed. If doing mid-pipes and such I'd probably go Kooks/ARH.
2018 ZL1 1LE - Summit White, PDR, Rotofab CAI, 95mm TB, CSP 2" catless LT's, JMS Voltage Booster, AEM X-series WB, DSX flex fuel sensor, Banks Data Monster, Tuned by Ted Jannetty, 5% Tint, Blackvue DR900S-2CH, Diode Dynamics lighting, IGL Kenzo ceramic coating
ZLE dude is offline   Reply With Quote
Old 02-03-2021, 07:58 PM   #33
Alain
Alain's Avatar
Sweet. I'm up north, Passaic County. Hopefully you're not too far.
I'd love to listen to that thing in person and maybe go for some drives this spring !
Old 02-03-2021, 08:11 PM   #34
20Bluezl1
That sounds like a plan I'm also in Passaic County
Old 02-03-2021, 08:19 PM   #35
Alain
Alain's Avatar
Bam!!!! I’m in wanaque.
Looking forward to the spring even more now Lolol.
Old 02-06-2021, 01:48 AM   #36
20Bluezl1
So I finally got to install my 2" ARH headers not easy all. Let my correct myself it's simple just time consuming and you have to he really patient.
So know I have a question I noticed a couple things that my ocd doesn't like. Passenger side the headers are really close to the hard brake lines. What are guys doing about that? Also I have read that the coolant lines should be relocated to be between the coolant tank and wheel well. I find that really tight and also the oem lines will be short.
On the Driver side the steering shaft lower bolt like pretty close the the headers. It has about a ¼" gap should I do something about this or should it be fine?
Old 02-06-2021, 02:01 AM   #37
IntimidatorZ
IntimidatorZ's Avatar
Drives: 14 Silvy 1500 Z71; 20 Camaro ZLE M6
Probably put on some heat shielding around where the headers are close to the brake lines. I wouldn't wanna role the dice with potentially melting through something as important as brake lines.
IntimidatorZ is offline   Reply With Quote
Old 02-06-2021, 10:20 AM   #38
20Bluezl1
Any recommendations what type of heat shield I should use?
Old 02-07-2021, 11:18 AM   #39
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
get the silver or gold reflective adhesive stuff in a roll available at most auto parts stores in the performance section or amazon.
Old 02-07-2021, 02:43 PM   #40
20Bluezl1
So im not sure which would be the best product yo keep the heat from the brake line. I found these products on Amazon but not sure if there's something better.
Dpesign Engineering 010408 Cool-Tape Self-Adhesive Heat Reflective Tape, 1.5" x 15' Roll, SILVER https://www.amazon.com/dpp/B000E283S...ing=UTF8&psc=1
Heat Shroud Sleeve Aluminized Sleeving Express Aluminized Hose and Silver Hose Wire Protection Barrier with Hook and Loop Closure, 3/4"I.D.x 10FT- 1" I.D.x 10FT https://www.amazon.com/dp/B08CRSJP9W...ing=UTF8&psc=1
A-Team Performance Heat Sheath Aluminized Sleeving for Ultimate Flex Seal Tape Heat Shield Protection Barrier 1/2" x 36" (3ft) Withstand 500 Degrees F to 2000 degrees F Radiant Heat https://www.amazon.com/dp/B07W7NSDTJ...ing=UTF8&psc=1
Also is the gold Reflective better then the silver?
Old 02-07-2021, 03:30 PM   #41
Wierd Harold
Drives: 2017 2lt rs
All be careful of the passenger side wire harness .reroute and protect it from excess heat
Wierd Harold is offline   Reply With Quote
Old 02-07-2021, 03:36 PM   #42
20Bluezl1
I'm going to relocate the wiring harness ( In red) and cover with a Reflective shield. Also the brake line (In blue ) is the line I want to protect.
