02-08-2021, 02:09 PM | #29 |
Drives: 15 SilveradoLTZ,162SSVert BlazerRS Join Date: Dec 2015
I'm in Naples Fl and can be at the beach in 15 Min. any day that I want. Its GREAT!!! Lots of REALLY nice cars down here as well.
02-08-2021, 03:29 PM | #30 | |
Drives: 2017 Camaro SS 1LE Join Date: Oct 2018
Now if you'll excuse me, I have to vacuum the acacia leaves out of the drainage channels on my Ford.... |
02-08-2021, 03:31 PM | #31 | |
Just filter the air, and they all have a drain on the bottom for when you're done. |
02-08-2021, 03:43 PM | #32 | |
Hot Camaro
It doesn't matter if you fully decompress the air tank and open the drain valve after every single use - the corrosion will still happen, it just takes longer. |
02-08-2021, 06:55 PM | #33 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
02-08-2021, 07:30 PM | #34 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
02-09-2021, 01:08 PM | #35 | |
Then you're saying it will corrode the metal inside of the tank, I also completely agree with this. I mentioned using a filter to keep this from impacting you where it matters, you suggested the same thing will also work. We agree here as well. I suggested draining the compressor after use, at no point did I suggest that this will combat simple science. This along with an inline filter will resolve the issues mentioned. So... we agree. My point was that we can't blanket this... top detailers globally use shop air to blow out interiors, exteriors, use tornadors etc. That is also actually true. There is literally nothing for us to disagree upon here, it seems. |
