#29 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2024 CT5-V Blackwing Join Date: Sep 2020
#30 | |||
![]() ![]() ![]() ![]() ![]() ![]() Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
If something is already there, you could buy an OBD2 splitter that gives you 2 OBD2 ports. That's the lazier and more expensive way, anyway. Quote:
The Uniden R7 works pretty well and has GPS which is a plus for traffic cameras. I got hit by tuose multiple times by those in Alberta. Quote:
It works on my 19, FWIW. I have PDR but not rearview camera(because 1LE). Sent from toaster or something
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
#31 | |
ALWAYS-N-BOOST
2021 ZLE comes with Rear View Camera
2012 1LS M6 Black-Sold 2013 2LT M6 BluRay- Sold 2015 1SS 1LE M6 Black-Sold 2021 ZLE A10 Riverside Blue - Awaiting Arrival 01/10 |
#32 |
Yeah, 1LE after 19 has rearview camera. Just not my 19.
Either way, that shouldn't make a difference in the connector. If it does, Gen5DIY asks you to put in the VIN when you buy the connector, so they make sure everything will be wired correctly with the options you have. Sent from toaster or something
Current:
#33 |
![]() Drives: 2018 Camaro ZL1 Join Date: Sep 2020
#34 | |
2018 ZLE - M6, Nightfall Gray
GM previously owned: 2014 SS M6 2014 ZL1 M6 2019 ZL1 M6 2016 Z06 M6 |
#35 | |
![]() I already received my BlendMount for my 2018 ZL1 and Thursday I will have my Escort RedLine 360C I ordered the power harness from Gen5DIY and got that a couple weeks ago. Looking forward to trying this out in the spring when I pull my car out of my garage from winter storage!
#36 |
![]() Drives: 19' ZL1, BMW F80 M3 Join Date: Jun 2016
For my Redline 360c I modified a Redenso XP visor mount by drilling a hole and bolting the magnet to it. I have the mount attached near the headliner with Velcro black ALFA-LOC fastener tape. I power it using the Gen5 harness plugged into the heater plug in the passenger footwell. The mount has a slight bounce due to the weight of the Redline, but it's not very noticeable. I've used the same ALFA-LOC tape to mount my dashcam and my Uniden R7 without any issues.
#37 |
![]() Drives: ‘21 ZL1 1LE 6MT Join Date: Jul 2012
I got mine from gen5diy and it works great and only took 20 minutes to install. I used the connector under the glove box like the directions said.
ZL1 1LE Black - 6MT - PDR - Nav - Michelin PS4s
#38 | |
#39 |
My instructions never said anything about using a glove box connector. I just watched the video and my harness wiring was nowhere near long enough to run across the top of the windshield, A-pillar to get under the glovebox.
#40 |
![]() Drives: 18 Ford Raptor, 21 2SS 1LE M6 Join Date: Dec 2020
I would contact gen5diy about your issue. I plan to get their radar and go pro wiring and have to figure out the mounting.
#41 |
#42 |
My last Camaro was a 2018 and the gen5diy harness I installed on that was much different than for the 2021. The new one takes a little longer to install but still easy. The 2018 clipped right under the OnStar console. The new one you just run down your pillar to the glove box.
They really do make great radar harnesses. They even made one for my wife’s 2020 traverse.
