Old 01-02-2021, 01:01 PM   #29
BlackbeastSS2
BlackbeastSS2's Avatar
Drives: 2019 Camaro 1LE Shock Candy
The Robert Frost mention is priceless. Not all would get it.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel
TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM
Diamond Piston & Manley Rods, Roto Fab Big Gulp
BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats
SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane.
2014 Mini Cooper countryman S All4 M6 daily driver
BlackbeastSS2 is offline   Reply With Quote
Old 01-02-2021, 01:01 PM   #30
Kerry
Drives: 2019 2SS Camaro
Does anyone see any evendence of deto on the piston?
This was a pure meth injection. no water so I dont see how it could be hydraulic? maybe
Im just looking for ansers and I appericate all input.
Plugs were the 6510 and looked perfect to me like they always look.
Kerry is offline   Reply With Quote
Old 01-02-2021, 01:36 PM   #31
Umbriel
Drives: 2016 Camaro SS
I'm assuming you meant port injection... Robert Frost isn't going to help your fueling. Lol
Adding port is actually not expensive, less than half of what the XDI stuff goes for and the
sky is the limit in terms of what you can fuel. I'm just trying to decide between Crawford and TooHighPSI setups.
Lol yeah, stupid auto correct on my phone. Port injection cost me a little over $5000 with boost control and to me that's expensive for fueling.
Sent from my SM-N986U using Tapatalk
Umbriel is offline   Reply With Quote
Old 01-02-2021, 04:42 PM   #32
95 imp
Dumb Ass Deluxe
It was a cold comment....
Old 01-02-2021, 04:48 PM   #33
95 imp
Dumb Ass Deluxe
Any fluid has hydraulic properties. But Ted is talking about the engine oil...
Old 01-03-2021, 12:48 PM   #34
JANNETTYRACING
JANNETTYRACING's Avatar
No sir I am not, I am referring to combustion chamber hydraulics.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 01-03-2021, 01:58 PM   #35
Kerry
Ted.
Not trying to be augrementive but are you saying that the methanol would cause a hydrolock type thing? Would you explaine the theroy on that?
Old 01-03-2021, 07:04 PM   #36
Herold Motorsports
Herold Motorsports's Avatar
Drives: 2017 Chevrolet Camaro SS
you were very lean. You want to get closer to the 12.0 mark but in reality you should be tuning in lambda not by afr.
For the meth however, I dont see a problem with it. We use methanol on TONS of builds and dont have any issues with them if the system is installed and tuned correctly. Methanol works when done right.
Even the single turbo car we just did was a methanol injected car, stock lt1 injectors, lt1 hpfp, 32% fuel lobe.
car made 740 on 10lbs. doesnt skip a beat.
Have one of my oldest builds still running strong on methanol also to date with a single 107mm build on a C6Z. Methanol works, and works very well.
Now meth should not truly be used as a dependent for fueling unless you plan on upgrading your fueling shortly after or you make sure that the right failsafes are set up in the vehicle in the event the methanol isn't spraying correctly. Without a failsafe, a methanol pump could fail and the car would be relying on something that isnt there anymore. If you dont have the set up to stop the car from grenading, it will.
as for your oil question we run LiquiMoly 20w-50 with Ceratec Modifiers in our Turbo Builds.
Herold Motorsports is offline   Reply With Quote
Old 01-03-2021, 07:14 PM   #37
Kerry
upon closer inspection looks like the passanger side rear is the one that went of course it took the one on the same journel with it.
Old 01-03-2021, 07:28 PM   #38
Kerry
RPM Raceing does a ton of methanol injected cars as well. Seems hard that a intake manifold full of methanol and air could to decied some cylinders are not going to get meth. Im sure its possiuble I think runners 2 and 7 are shorter on the lt1 manifold. So ?
I will go to the lt2 intake as all runners are supposed to be the same lenth and has better distrubtion they say.
I though I read on the form from some that you could be too rich and cause problems and the some say too lean. confuesing. I know stock the car runs 12.5 course thats na
I certinaly appericat all the input and pleas keep posting what you think.
Old 01-03-2021, 07:35 PM   #39
Herold Motorsports
Weird suggestion but I have seen it before. Methanol has to be sprayed through a nozzle at a minimum of 50psig. If not it cannot atomize properly pre-intake manifold and wont distribute correctly. Ensure the pump is operating correctly and that there is no clogs or kinks in the line.
Old 01-03-2021, 08:00 PM   #40
Kerry
it was comeing on at 2 psi green light indcateing 50 minum psi and going to 135 psi at shift 8.5 psi boost measured right befor the nozzels
Old 01-06-2021, 09:34 AM   #41
Kerry
Need some help. I pulled the pickup out of the oil pan to make sure everything was good. Their is somekind of sealant that goes on the tube that inserts into the oil pan opposite end of the pick up screen. Anyone know what that is and where I could get some?
Old 01-20-2021, 05:31 PM   #42
Kerry
So it seems that the concisis is running to lean. What should i run afr or lamda what ever u like. Is 11.5 too much. im not interested in setting a record just want it to last.
