#29 | |
![]() Drives: 2016 Camaro 2SS Join Date: Feb 2020
Going to keep the stock intake after looking into options, one less variable right now to deal with. Will figure out the PI when/if I get bored of this setup.
16 Camaro 2SS - Turbo 7675CEA
85 Grand National - 03 Sierra - Prostreet TVS1900 |
#30 | ||
![]() ![]() ![]() Drives: 2016 Camaro SS Join Date: Sep 2018
Here you can watch my tuner go WOT with it doing the street tune. https://youtu.be/_6eGzTUGWus?t=472 |
#31 |
#32 |
![]() ![]() ![]() ![]() ![]() Drives: 17 SS a8 Join Date: Feb 2010
A friend of mine has the G1pro intake with rails and 1050x injectors for sale. It is short like the procharger one. It might even be the same intake.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
#33 |
It can get crazy when the boost comes in, I know on my old Camaro when I was doing some street logging and we were at 850 plus rwhp it can get out of control pretty fast with street tires. Even with my Street Rs (305-45-17) I needed to be on a little rougher asphalt or concrete just to get a decent log and that was in 4th to 5th gear. I know everyone wants a 1000 rwhp on the street but that much hp in a rookie drivers hands can be a disaster. I've been drag racing for 53 years and I can tell you its a load to handle it. Been there and done it all. So careful what you wish for.
#34 | |
Moderator
![]() Do yourself a favor and buy the entire BMR catalog for the rear suspension. Got way too squirrelly for my taste on the street with the stock suspension.
#35 | |
Sent from my SM-N986U using Tapatalk |
#36 | |
Moderator
#37 | |
#38 | |
Old badass
Drives: 14GMC 2.9 16GMC Turbos 2020Silv.6.2 Join Date: Mar 2020
#39 | |
#40 | |
#41 |
![]() Drives: 2019 Camaro SS 1LE Join Date: Jul 2020
ok how in gods name did you fit a 4" DP through there?...Im sussin out this engine bay for my turbo build and it is tight...going to be a ton of crap to move.
and im assuming a custom ac line was put in place for the driver side? |
#42 |
DP is routed to passenger side, and only 3". At that, it's touching firewall. 4" would not fit for any kit similar in size without massaging the firewall and/or routing
