Old 12-23-2020, 02:53 PM   #29
az4783054
Drives: SWXXZL1
I built a number of modified tri five Chevy cars with high compression motors, headers and AZ heat. I used the braided type ground straps in various lengths/widths. Multiple grounds to points on the chassis. Redundant but never had a slow cranking issue with the cars. Make sure that the attachment point is clean for the best connection.
"Joe" does a hilarious impression of a slinky toy on stairs.
az4783054 is offline   Reply With Quote
Old 12-23-2020, 03:08 PM   #30
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
Originally Posted by Invertalon View Post
What bolt size to attach the opposite end to the engine block? I assume you have to buy that, as mine has no bolt in that position from the factory.
I don't know the bolt size. The bolt head takes a 15mm socket.
I didn't buy the bolt. It was already there.
476 rwhp/440 rwtq (sold)
Old 12-23-2020, 05:29 PM   #31
MackSteelPrivateEye
I'll probably add one as a precaution in the spring when the weather heats up.
Old 12-23-2020, 07:31 PM   #32
pauly1119
pauly1119's Avatar
Drives: 2018 ZLE
Funny I added one to my Escalade which made me buy a jump pack after getting stranded a time or two prior to adding the cable and it also fixed the problem. Now the jump pack was dead because it just sits now.
pauly1119 is offline   Reply With Quote
Old 12-24-2020, 12:52 PM   #33
fxdxron1
Drives: 2016 Camaro 1SS
I have also had the same problem on my 2016 SS. I am on my fourth battery in four and a half years three replaced by the dealer the other person that posted a new battery makes the problem go away for awhile is 100% correct I have found that in all the new batteries that were installed that the problem was better for several months.
fxdxron1 is offline   Reply With Quote
Old 12-24-2020, 05:13 PM   #34
SSDan
SSDan's Avatar
Put a new ground cable on it. What do you have to loose? Its certainly less money than another new battery.
Originally Posted by tadre1 View Post
My 2016 has no power .. can I put one of these cables on .. and will magically start??
I've read your thread and can totally understand your frustration.
Hey, its's Christmas Eve - throw a new ground cable on there - maybe you'll get a Christmas miracle. But seriously I hope you can get this fixed and put it behind you.
Old 12-24-2020, 07:46 PM   #35
fxdxron1
I purchased the ground cable today I will keep you guys posted on if it works
Old 12-24-2020, 09:25 PM   #36
MackSteelPrivateEye
Honestly I had an extra ground wire to the block #6 gage wire .. I took it off so they would not blame it on the issues happening now. But yeah .. it happened with that extra ground wire attached to the block .. so I don't know what to think .. someone else posted that extra ground wire here somewhere .. so I had it on for at least 1 year .. and just took it off now. I put it on in Aug of 2019.
What the dealer say?
Old 12-25-2020, 10:46 AM   #37
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
Originally Posted by SSDan View Post
Here is where I bought the cable.
https://www.lethalgarage.com/product...d8ecfe34&_ss=r
No doubt I paid more than I had to but I tripped across this item on another thread and decided - what the heck do I have to loose. Also the cable I bought is heavier gauge (thickness) than the Autozone one which will give better results. I think of it this way - Yes I over spent $40.00 on an item I could probably get elsewhere for much less - but that $40.00 made the number one most frustrating issue I've had with this car for years go away. For my peace of mind that is money well spent.
Awesome post, and I agree, $40 well spent. Looks like a nice beefy cable.
Old 12-26-2020, 02:49 PM   #38
teddyca
teddyca's Avatar
Drives: Blown C7 and 6th gen
Here are my notes. The lug nut on the radiator support is 13mm a wrench is fine. The bolt you used is for MY pulley system??? it is 15mm and was a pain with my MM catch can in the way. I should of moved it. Once I got that long ass bolt out the tension of the belt released. Damn it I should of paid attention. Now time to address. BTW I love Lethal and putting on his flex fuel kit after I deal with this BUT I had a "Super Start, Battery Cable, 4ga, 19in " I think that is an Autozone part. I had it laying around in my shop and it looks perfect.
14 Corvette Z51 Coupe - 655RWHP
A&A Ti Blower, Alky Control Meth kit, Kooks LT setup, Corsa Catback, Full APR CF kit, RK Sports CF hood, hell CF everything LOL
17 Camaro 2SS 50th edition. TOTALED 6/2019
K&N Intake, MRBP axleback, Eibach kit, 20" Z28 wheels, smoked lights all the way around, Rockford Fosgate system
17 Camaro 2SS 50th edition. Round 2- 8/2019 550/600 RWHP, Magnuson TVS2300, Rotofab Intake, Corsa Xtreme, Air Lift P3 System, 20" Stance SF-07, smoked lights all the way around, Rockford Fosgate system.
teddyca is offline   Reply With Quote
Old 12-26-2020, 03:03 PM   #39
SSDan
SSDan's Avatar
I just went back and listened to my video on the install location and realized I failed to mention that the engine bolt I used is part of the serpentine belt system. I didn't take the bolt all the way out. I just loosened it and then cut a small piece out of the ear of the lug and slid the lug under the bolt and tightened it down.
I'm sorry about that Teddyca! I apologize. I just went back to my first post and added an edit to point that out.
I hope its not too much work getting that belt tight again.
Old 12-27-2020, 01:51 PM   #40
teddyca
teddyca's Avatar
Dan- You came up with a great idea and a great writeup. I failed to pay attention. That's all me I am very grateful of your writeup and thank you. I got worse yesterday. By forcing the bolt back in for the serpentine I bent it and had to cut it to free it up. Now I have to wait for the dealer tomorrow to order another one. I went to OSH and found one close but with the tension I cant get it back together. I am missing something I am sure of it. I tend to struggle with the simple shit. LOL Truly appreciate your writeup my friend.
Old 12-28-2020, 07:29 PM   #41
RA1987
RA1987's Avatar
Drives: SS
Ordered the cable from Lethal Garage. Cable is now in-transit.
Thank you all
RA1987 is offline   Reply With Quote
Old 12-29-2020, 04:04 PM   #42
RA1987
RA1987's Avatar
Drives: SS
Update:
It works!
