Old 12-19-2020, 08:08 AM   #29
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by ramairroughneck View Post
I just don’t see it being a methanol distribution issue. There are a million and five people running methanol and most are not direct. A MSD is not restrictive or a particularly long runner intake. If your meth tank was full and your fuel pumps had a sufficient level to keep them primed, my guess is your fuel system was on the ragged edge of being capable enough to support your setup. The lack of miles and the cooler air requiring more fuel leads me to believe you may have not ever had an adequate supply for this setup. Prochargers have a sharp power curve that has a very slim peak. They don’t draw as much fuel early on or even through the mid range. It could very well be that insufficient fueling wasn’t discovered on your tuning day. It’s all speculation though. Really everyone of us could be wrong and I’m fully onboard with the others notations about using bigger injectors or secondary supplemental injectors as a safer alternative for a powerful build like this.
Let me help you understand.
If it was not a distribution issue all 8 would have failed not just 1.
The fact that 1 cylinder failed is direct evidence of a distribution issue.
Just because a lot of people are doing something wrong doesn't make it right.
Originally Posted by 95 imp View Post
My vote is it leaned out too.
IMO, the manifold is designed to be dry flow. Try to make it a wet flow and you will get fuel separation/fall out/distribution issues.
"Just because you can doesn't mean you should"....
This
www.jannettyracing.com
email tedj@jannettyracing.com
Old 12-19-2020, 09:18 AM   #30
Prochargedgen6
Drives: 2017 procharged camaro 2ss
Thanks for all the input from everyone, and, that's done, so my biggest concern is not to do this again, going secondary port injection, back off the meth, go full E85, and try again, did I mention that was on ms109 too?
Prochargedgen6 is offline   Reply With Quote
Old 12-19-2020, 09:24 AM   #31
Prochargedgen6
And it wasn't even that much of a hit, like a 40-140 and 4 gears, zero warning, no popping or banging out, just a horrible smell and a little (wife says alot) sideways, maybe 6/7 seconds and that was the end if it, no front main, instantly filled the catch can, blew the vacuum hoses off oil soaked and smoke everywhere, but we didn't even get close to the guardrail(s)
Old 12-19-2020, 09:35 AM   #32
Umbriel
Drives: 2016 Camaro SS
The way to go is definitely port injection.
Sent from my SM-N986U using Tapatalk
Umbriel is offline   Reply With Quote
Old 12-19-2020, 10:48 AM   #33
supersportss
Drives: 2019 SS
Jannetty just gave all of you the answer, pay attention.
supersportss is offline   Reply With Quote
Old 12-19-2020, 01:51 PM   #34
parish8
Drives: 17 SS a8
It could be a distribution issue. I would like to the what the wideband said at the end of that run.
I have seen(and done) lots of stupid things. Ran myself out of meth. Raced with low fuel and am aux pump, ran out of fuel system due to colder weather... there are lots of ways to run out of fuel. If your tuned perfectly and it gets colder the meth kit won’t know to flow more fuel. The stock ecm will but it may not be enough.
If you want to run 20psi you should just step up to port and e85.
Old 12-19-2020, 01:55 PM   #35
Umbriel
Yep, I plan on 20 to 25 pounds on kill mode and went with port injection.
Old 12-21-2020, 11:05 AM   #36
JANNETTYRACING
LOL just like when you lose an item, and are running around like a chicken with the head cut off looking for it and it is sitting right in front of you.
Ted.
Old 12-21-2020, 11:12 AM   #37
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
how much meth were you spraying?
the log file would be greatly beneficial to this..... I would like to see it and am curious about more details about your setup.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 12-21-2020, 12:32 PM   #38
parish8
Drives: 17 SS a8
I don’t think a melted 7 piston necessarily points toward a distribution issue. If your lean across the board(without meth) #7 is likely the first to go. He could be lean across the board for some reason.
I am curious if there is some amount of single nozzle meth you can spray that gets so evaporated it does distribute well. Like 100hp worth in 1000+ hp worth of hot air. Maybe egt’s would help show this.
Old 12-21-2020, 12:41 PM   #39
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
I could see that on a SBE but with a forged piston that is normally more tolerant I would think you would have to be excessively lean on that cylinder for it to let go under the conditions the car was operated. It's not like it was a mile long pull. Something would have to be way off to melt a forged slug that fast on a little test hit no?
Old 12-22-2020, 06:28 AM   #40
Prochargedgen6
If I knew how to post the log I will, I email them to my tuner, know how to do that, ideas?
Old 12-22-2020, 07:13 AM   #41
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Could upload it to Google Drive and share the link.
Old 12-22-2020, 07:33 AM   #42
danhr
BAMF SS
danhr's Avatar
if you are willing to email it, pm me, and I will shoot you my e-mail address and you can just send it via e-mail
Stock Longblock
