Old 12-29-2020, 09:04 AM   #29
GTPprix
I hack cars.
Drives: Lots ;)
You have 3.5 hardware in your 2020 the kits are the new 3.6 revision.
GTPprix is offline   Reply With Quote
Old 12-29-2020, 09:08 AM   #30
ember1205
Hot Camaro
ember1205's Avatar
Can you elaborate on why the link you provided says that 2019 model year testing is still pending? If it's only a HW swap, I'm curious why this wouldn't "just work" all the way back to 2016? Or, at least for 2019 and up?
Old 12-29-2020, 09:13 AM   #31
GTPprix
I hack cars.
Drives: Lots ;)
Wireless CarPlay on 2016-2020 possibly??
Because the 2019 is missing other hardware and there was a coordinated change in two other subsystems that needs to be tested thoroughly. It’s also not only a hardware swap there is a custom programming involved as well as ton of other issues for example getting the units registered properly with GM etc it’s a big deal to do this properly and have it all be OEM and properly interface with everything else as if it was built that way.
Old 12-29-2020, 10:49 AM   #32
LTwin86
LTwin86's Avatar
Drives: 2017 2LT RS
Actually that kit is a smoking deal if you have an IOS equipped Vehicle. Retail on the module alone is $825 plus another $300+ for the map database card plus the custom programming you get to enable NAV as well as HD radio etc. They also come pre registered on the GM back end which you cant do with used modules but you dont have onstar in your market so its not as big of a deal.
Currently i have 2019 HMI on my 2017 car, and it is also have no OnStar. Works perfect, seems no problem with Onstar.
GTPprix, please send me a private message, i have one question. Sending you private message is blocked.
LTwin86 is offline   Reply With Quote
Old 12-30-2020, 01:19 PM   #33
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
You can message them here: https://www.whiteautoandmedia.com/contact-us/
Chris is definitely the go-to man for this
2016 1LT v6
- Totaled
Happiness: Infinite
Old 01-31-2022, 08:54 PM   #34
Plasar
Drives: 2017 ZL1 Vert M6
Update:
  • Finally, after the latest firmware update, this CarPlay2Air thing connects reliably every time - it only took 1 year!
  • Below is the update YouTube.
https://youtu.be/ZqGyFQtXlLw
Plasar is offline   Reply With Quote
