#29 |
Go to manual, put it in the gear you want & then switch to auto as soon as you punch it.
2020 ZLE Roto-Fab dry
2018 Camaro 2SS 1LE - 2" TSP catless headers, Pray Ported stock IM/TB, Rotofab dry, DSX FF kit, dyno tuned by Pray. SOLD |
#30 |
I spend most of the time in Manual using the HUD and shifting in the 6000-6200 rpm range. If I wait to get to 6200 before pulling the paddle I'll sometimes hit the rev limiter which I definitely want to avoid.
2020 ZL1LE A10.
LME LT4 390 short block, LME CID Heads, Kong E2650, FBO. 15" conversion, MT ET Street R 325/15. 100 octane: 1045hp/1055tq. 100 octane + Meth (1x10+): 1117 hp/1067 tq |
#31 | |
Used to own a ZL1
Drives: '16 Z06 Join Date: Apr 2020
1. switch to manual 2. downshift to preferred gear 3. beep beep beep 4. floor it, and slap it back into auto You can also have someone tune your transmission to where it will automatically upshift in manual mode as well. |
#32 | |
#33 | |
Used to own a ZL1
#34 | |
The absolute best alternative IMO is KingLT1's legendary trick (see here) to tweak TUTD speeds so the trans shifts automatically at the desired mph/rpm even in manual mode, but otherwise doesn't interfere. With this you can stay in manual mode all the time and either use the paddles or just keep it floored and the trans will shift for you. Downside of course is that this is a tune change, so you need HP Tuners and the willingness to kiss the warranty goodbye.
#35 |
![]() ![]() Drives: The DSSV Twins: ZR2 and ZLE A10 Join Date: Oct 2019
It's magic and I love it.
#36 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
🔺22 RS E TRON GT
🔺21 Model S Plaid |
#37 |
Why did GM make this transmission so difficult for the customer to understand? Rhetorical question
2020 ZL1LE A10.
#38 |
![]() Drives: 2012 Saleen 620 Yellow Label #7/13 Join Date: Apr 2014
#39 |
Johnny Z
Drives: Chevrolet ZL1 Camaro 1LE Join Date: Jan 2020
Auto
#40 |
Easier for mere mortals to drive 10/10s with the A10
#41 |
Having a ball everyday! Plan to drive it year round except for a few snow/ice and <20F days.
2020 ZL1LE A10.
#42 |
![]() Drives: Canadian 2019 BLACK ZL1 Join Date: Feb 2020
