#29 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Not certain but I guess they used the original map sensor. Are those not able to handle 15 to 16psi?
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
#30 |
Dyno Show Queen LOL
Ya there ok to that psi
#31 |
Former GM Technician
Drives: 2018 ZL1 A10, 06 Silverado Duramax Join Date: Sep 2009
Do you have a Dragy? This way you could compare the 60mph to 130mph with others...
Here is one to compare (800rwhp) https://www.camaro6.com/forums/showt...0877499&nojs=1
2018 Camaro ZL1 A10
Rotofab Big Gulp, Nick Williams 103, Magnuson 2650, 9.17" (14%) lower, 90mm upper, Vengeance Racing Heads (LME) Cam Package (Cammotion Stage 1), Johnson Lifters, DSX dual intank pump, Lingenfelter high flow check valve, Motion Raceworks Flex Fuel adapter, LPE Big Bore Hpfp, XDI 30% Injectors, BBK shorty headers, Custom 2.75" down pipes, Gesi Gen2 high flow cats, MM catch can. 2006 Silverado Duramax Diesel MPI Compound Turbo 40% over Injectors Efi Live DSP5 Tuning Follow me on Instagram: SwissZL1 |
#32 | |
#33 |
I don't know this to be 100% true, but when I was looking one of the Janetty videos it shows STP power and from what I could find that is usually 2.5% higher than SAE.
#34 |
![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
At any rate I believe with your mods you should be more
Like 775whp or greater at SAE if not 800whp STD. |
#35 |
According to the online dyno calculator it said 768 sae and 797 std. Since I don't know exact time of day I had to avg temp, pressure, and humidity
#36 |
Here is a link to the dyno Calc I used
https://robrobinette.com/Dyno_Correction_Calculator.htm
#37 | |
![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL1 Join Date: Mar 2019
That's correct as STD is based off 60f and 0% humidity, 2.6% typical Just a note: Uncorrected will usually be lower then SAE unless you are dynoing in very cool temps with very low humidity. Then you will start seeing uncorrected higher then SAE as SAE is correcting to 77f degrees. |
#38 |
![]() Drives: 2018 zl1 10 speed Join Date: Oct 2018
#39 |
thanks for the update! Any idea if your dyno numbers were read with SAE or STD ?
#40 |
Dyno Show Queen LOL
Maybe this will help..
Here is a Jannetty video with the same mods different cam and 95mm TB kit vs your 103mm... 840 STP https://www.facebook.com/watch/live/...atch_permalink holy smokes batman i think mines in SAE all ready.
#41 |
Dyno Show Queen LOL
https://ccnorcal.com/magnuson-superc...m-di-tvs2650r/
^ This was the video I was referring to granted its a vette should not make a difference unless it doesn't have a good 1 to 1 gear to use. but it made 728 rwhp on a otherwise stock car. you have a lot more mods. 750 is low even it the sheet is SAE.
#42 |
