#29 |
Who Needs to KNOW?
I have close to 2 years ( 20,000+ miles) on my MP4S with plenty of life left. They are excellent daily tire.. just not snow compatible.
#30 | |
![]() Drives: none Join Date: Jan 2019
Conti DWS 06 will do the business. The Pirelli P7 and NERO family all seasons are just appallingly bad. The summer '80' rating tires are tolerable but obviously hot weather only. General GMAX A/S are not too expensive and do a credible job. I prefer the Conti but some people don't like their soft sidewalls. You own a Camaro, the days of Civic budget are LONG gone. |
#31 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
I drive with NON-RF tires from day one.....
2012 Yukon XL Denali w/ 6.2 AWD |
#32 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
If you're going to drive thse types of cars you'd better have a tire budget. It's all relative but you're going to spend money on tires even just driving it around normally you're going to go through tires much faster than a Camry. Remember staggered setups manufacturers halve the mileage warranty and too that you can't rotate 'em. Getting 20K on a set of summer style tires is fair. Of course you can't account for how people maintain their cars with tire pressure and maint either.
#33 |
![]() Drives: 2017 Camaro 2.0T, 91 Miata Join Date: Jan 2020
On a car like a Camaro, especially the heavier V8 models with staggered tires, you're doing good if you get more than 20k miles out of a set of summer tires. With a decent all season, you're likely to about double that.
Make sure you get a good alignment. A bad alignment, namely bad toe, will eat tires in just a few thousand miles.
#34 |
3/10 Vehicle Mechanic
Drives: 17 Camaro SS Join Date: Aug 2020
I'm leaning either the Indy 500's or the MP4S's, unless some of you fine folks can offer other tires with better results given my driving intentions.
Also, any experiences with these two tires pros and cons, other than those who've already testified, would be greatly appreciated. |
#35 |
avoid Runflat like the plague. Unless you have a history of getting frequent flats where you drive. For any kind of sane public road driving the 300-400 all-seasons are MORE tire than you can possibly use. Why pay extra for summer-only?
If you're gonna spend your summers tearing up Hot Springs AK, or TN/KY backroads then maybe Summers would be very slightly more fun. |
#36 |
![]() Drives: 2016 Camaro SS Join Date: Oct 2020
I bought a used camaro ss a few months ago. It came with all season tires on it - Toyo extensa hp II. Now these are not tires I would have ever considered buying - but I really can’t complain about them. As the poster above said - I live in Hot Springs and drive around backroads here at twice the posted speed and the car is very planted. I’m sure they break loose easier from a stop than summer tires, but really that is part of the fun for me. I’m not taking my car to the track of the drag strip - just hauling ass around town and having fun with the car.
Just posting to let you know that you don’t absolutely have to spend a ton on tires if you don’t have the budget for it. Depending on what you plan on doing, the cheaper tires may be fine. |
#37 | |
#38 |
![]() Drives: 2021 2SS Join Date: Jul 2020
I got my car a few weeks ago and swapped out the summer run flats with Michelin A/S 3+ non run-flats. Cost me $1300 I believe out the door for all (4) for the SS with the tire replacement certificates and install at Discount Tire.
Because we have no jack/spare/etc... I bought a tire-plug kit and 'TPMS safe' fix a flat and threw both into my trunk. If neither of those will work in case of a flat, it will get towed. In my 15 years or so of driving (and hundreds of thousands of miles), I never had a flat that stranded me or required a side of the road repair. Typically any screw/bolt/etc... Would be a slow leak that would allow me to get to a shop or pull the tire off at home and take it myself somewhere. Most tires blow catastrophically due to improper air pressure, overloading, tire age, excessive wear, etc... Rarely does it occur due to defect, for example (but does happen, of course). So I personally have no fear running non RF tires without a spare. At worst, for critical failure I will get towed somewhere (covered under my insurance and with Michelin). Because I am unable to rotate my tires front-to-back, I expect I will replace my rear set of tires a bit more often then the fronts. |
#39 | |
I don't doubt the Michelin is a better tire, but is it almost TWICE as good as the General? |
#40 |
![]() ![]() ![]() Drives: 2023 2SS Convertible Join Date: May 2009
I think I paid around $1400 at the Chevy dealer for my Pilot Sports. They matched the best price I could find online (Discount Tire was lowest). Plus it always helps you buildup goodwill with them by spending cash there in case you need some warranty work out of warranty.
-Geoff
#41 | |
#42 |
no the Mich are not 2x as good as the G-max
