#29 |
![]() Drives: 17 ZL1 Black M6 Join Date: Sep 2016
#30 | |
![]() Drives: 2018 ZL1 A10 Nightfall Gray Join Date: Apr 2016
Little hit on my recent trip to Mexico, I have seen 212, but didn't have the PDR on, as you can see it was still pulling good at 200. Not sure what it would top out at. |
#31 |
![]() ![]() ![]() Drives: 2018 ZL-1 Join Date: Jan 2018
I wish I had used my PDR on my run.
#32 | ||
#33 | |
It was on the stock wheels and tires. |
#34 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 Red Hot ZL1 Join Date: Sep 2020
#35 |
#36 | |
#37 | |
![]() ![]() Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
1LE with the big wing and the down force at high speed is slower than the regular ZL1. Same M6 and A10 have different ratio The top speed should be reached by a regular ZL1 A10. |
#38 | |
![]() Drives: '20 ZL1 M6 Join Date: Apr 2017
Mal
Ft. Lauderdale, FL '20 Camaro ZL1 M6 '22 Kawasaki ZX-14R |
#39 |
![]() Drives: women crazy Join Date: Aug 2020
A warning to slow down. And a lecture that it's not worth it to avoid the Redbox late fee.
‘19 1SS A10, Borla S-type Non-NPP-SOLD
#40 |
I've come close enough to 200mph to know this car can do it but the next problem for us is that 99% of highways are ill-suited for such speeds.
I wonder where Chev went to confirm their 200mph numbers? Indy?
2020 ZL1LE A10.
LME LT4 390 short block, CID Heads, Kong E2650, FBO. 15" conversion, Nitto 555Rii or MT ET Street R or Toyo Proxes RR. 100 octane: 1045hp/1055tq. 100 octane + Alky MAF Meth (1) 10+: |
#41 |
You can see in the video the road was clear, and it doesn't take long to be there and back down to speed limit when on the interstate.
#42 |
![]() Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
Here in Texas my neck of the woods, the elevation is 300 feet above sea level, I would imagine anyone with the ****s could pull 200 for sure, good tires no hog's, or texting people in the way. I have a unrestricted ZX14R which I'm sure with someone about a foot shorter than my 6'4 could pull 203-205 mph, years ago on my 02 hayabusa 1397cc big bore kit , cam, air shifter, Ackropovic ti pipe, stock wheelbase 200 hp ,I went across a bridge, when I went from the hwy to the expansion joint on the bridge at indicated 185-190 (probably 175 actually speed correction 3% off or so)mph the bike lifted about a foot to two off the ground ! Nothing you can do but ride it out ! It's was a great feeling I was 32 then ! I might try 160 in the ZL1 one day but I rather go to a land speed event !
