Old 05-14-2020, 01:55 PM   #29
Abubaca
Abubaca's Avatar
Drives: 2016 SS
Now that you mention that I wonder if mine is pre wired for it? Probably not as I have the 1ss dual exhaust
Well the wiring is the easy part. The hard part, if even possible, would be to get the control/function from the touchscreen. Software stuff like that is well above my paygrade! ...that being said, not having "factory" control allows for some cool hotrodding options. On my Iroc, the two window switches were on the center console. I added a third, factory switch, wired to the cutout. While not a factory option, it was about as "stock" appearing as you could ask for!
Abubaca is offline   Reply With Quote
Old 05-14-2020, 02:12 PM   #30
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Originally Posted by Abubaca View Post
Yeah....I mean it's nice that it's programmed into the touchscreen software, but these systems are hardly anything new. People love 'em though! ...and if your car is already wired for NPP/dual mode, you can just buy the valves and weld them in post cat like you said and you still have touchscreen control. MUCH louder than stock NPP, and a whole heck of a lot cheaper!
Actually, The NPP programming isn't based in the Infotainment software. The NPP valve programming is located in the FSCM controller and I am almost positive it is there for all models. It's simply disabled for non NPP cars. So you would have to enable it in the software which can be done with HPtuners and 1 credit 50.00. The FSCM is a separate controller from the ECU, so you should be able to flash it without voiding the warranty. That being said, I prefer to use the performance modes switch and I have my NPP valves tuned differently for all 3 modes.
Old 05-14-2020, 02:25 PM   #31
Abubaca
Abubaca's Avatar
Drives: 2016 SS
Well that's cool....I didn't know that! Pretty cool!
Old 05-14-2020, 10:20 PM   #32
DNSS2
Drives: 2017 Camaro 2SS
If anyone has the old one without the valves and is looking to switch to the new one, I will buy the old one.
DNSS2 is offline   Reply With Quote
Old 05-15-2020, 02:51 PM   #33
Zr8000
Drives: Chevy Camaro
Good info. Did you make your own valve setting using the hp tuner?
Zr8000 is offline   Reply With Quote
Old 07-13-2020, 12:16 PM   #34
tawheed
Drives: 17 ZL1
Corsa now has an NPP option
Not sure how new this is, I only noticed it today. Looks like Corsa finally has a valved rear section option for our cars.
Check it out here.
tawheed is offline   Reply With Quote
Old 07-13-2020, 12:21 PM   #35
KingLT1
KingLT1's Avatar
Yep there was a thread in the general section on it. It's been out since May...kind of pricey but part of me still wants to pull the trigger on it since it has no drone and a 12db difference between open and closed modes. I like my current Flowmaster NPP for the money but it's not perfect.
Side note you can get it cheaper through another vendor.
Old 07-13-2020, 12:32 PM   #36
tawheed
Drives: 17 ZL1
Thanks for letting me know! Mods can probably delete this thread!
Old 07-13-2020, 12:36 PM   #37
oldman
Drives: SS 6 speed of course
Corsa,,, so good,
Old 07-13-2020, 12:39 PM   #38
KingLT1
KingLT1's Avatar
Honestly the thread should be here since it's a bolt-on modification.
Old 07-13-2020, 02:36 PM   #39
jaybee924
Drives: R.I.P. 2021 ZL1 & 2019 Rd Garn 2SS
On your flowmaster what's going on with it? I've eye balled it a couple of times.
jaybee924 is offline   Reply With Quote
Old 07-13-2020, 03:09 PM   #40
KingLT1
KingLT1's Avatar
Nothing terrible...it just has a little more drone(14-1600rpm) then I care for when the valves are open and when they are closed you can hear a hiss from exhaust leaking past the valves(only when standing behind the car).
Old 07-14-2020, 05:55 PM   #41
jaybee924
King if you decide to bite the bullet and want to let go of the flowmaster let me know.
Old 07-14-2020, 07:07 PM   #42
BigGuy81
Drives: Man
Send a message via ICQ to BigGuy81 Send a message via AIM to BigGuy81 Send a message via Yahoo to BigGuy81
$2k? That’s a no from me.
BigGuy81 is offline   Reply With Quote
