#29 | |
![]() ![]() Drives: 2018 ZLE (M6/hyper blue) Join Date: Nov 2015
Guess I'm ordering TPMS sensors :| |
#30 |
![]() Drives: 19' ZL1, BMW F80 M3 Join Date: Jun 2016
Been there, done that too.
#31 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
Yeah HoodCheck it’s those TPMS sensors. You have to use sensors for 6gens!
#32 |
#33 |
For the TPMS sensors...can't program them, but oddly I do show tire pressures on the dash...3 have changed by 1psi since the install they say....kind of wierd.
I noticed tonight when installed the rock guards that the clearance behind the wheel at full turn is basically non-existent. Think I might end up snagging some spacers for the front. |
#34 |
![]() Drives: 2018 ZL1 1998 SS 1992 Typhoon Join Date: Nov 2015
They look good, what size tires did you use? My rears stick out a little passed the fenders.
#35 |
#36 |
2019 ZL1 1LE MY GOON
Drives: 1980 Z28 Big Red. Join Date: Dec 2018
#37 |
Well, it was very odd, but the gen5 tpms sensors were actually giving a read out, including changes in pressures, for about 25 miles...then the service tire pressure monitor system light popped on finally, and the readings turned to dashes. Swapped with the correct TPMS sensors and was good to go. I went ahead and added 5mm spacers to the front to provide a littler more clearance, because I don't have a grinder to cut/notch the strut at the moment (I may still have a shop do this). That spot on the strut was too close for comfort for me.
