Old 07-07-2020, 09:24 PM   #29
jbuenavides
Drives: 2017 Chevy Camaro
Oh no, it seems like they failed to do quality checks for these tires. They don't look new to me.
jbuenavides is offline   Reply With Quote
Old 07-07-2020, 09:57 PM   #30
Rodan
Drives: 2018 ZL1 coupe
Under the circumstances described, I would absolutely expect the tires to be replaced by the selling dealer... they can fight with GM over who gets to pay.
When we bought our ZL1 in early November of '18, the dealer was completely clueless about this tire issue. I checked them carefully, since I knew the car had been outside overnight (along with several 'Vettes). First thing I did was get a set of A/S tires, and a second set of wheels for the SC3s...
Rodan is offline   Reply With Quote
Old 07-07-2020, 10:41 PM   #31
ZL1 affair
ZL1 affair's Avatar
Drives: 1of 66 Orange Crush 2020 ZL1’s
UPDATE:
My service advisor called me today and said they are going to bring a set of tires in for the car. Apparently the warranty rep is being a douche about replacing the tires and thinks the dealer is at fault for the damage done. This blows my mind as GM shipped this car in the middle of winter! Would seem pretty reasonable that the tires were damage during shipping.
I am happy this is going to be resolved and I didn't have to fight for it. This is one of the reasons I deal with this dealer, can't find any near me that are this good and treat customers like they should be treated. Totally worth my time and the drive.
Dreaming of a 2020 A10Crush ZL1 *TPW Sept 30* Built November 14, 2019, shipped Nov 15, 2019. Arrived at the dealer January 29, 2020.
2013 CTSV coupe 6MT SOLD
ZL1 affair is offline   Reply With Quote
Old 07-07-2020, 10:44 PM   #32
ZL1 affair
ZL1 affair's Avatar
Originally Posted by Drews View Post
Thanks for the "heads-up" on the cracked tires ZL1 affair... i'll be sure to check mine promptly.
I had checked mine upon delivery at end of january 2020 ( since we both live in canada and had about the same frustrating situation with the strikes and delivery) ... but, i had only checked the side-walls.
You could have possibly saved my life buddy!
Thanks!
Take care buddy
Andrew
Yes, get them inspected! Hopefully yours will be ok, mine probably cracked as the car was moved west into the deep freeze
Old 07-08-2020, 01:43 AM   #33
Yves ZL1
Yves ZL1's Avatar
Drives: Canadian 2019 BLACK ZL1
How much kilomèters on yours ?
Mine was from may and i wish there won’t be the same problem...
126 km for mine but she was from Montréal.. I pray
Yves ZL1 is offline   Reply With Quote
Old 07-08-2020, 10:14 AM   #34
ZL1 affair
ZL1 affair's Avatar
My car was delivered to me with 6 kms showing, found the cracks at 420 kms and the it now has 650 kms.
Old 07-08-2020, 10:42 AM   #35
Tyrolblue67
Drives: 2019 ZL1 Camaro
I store my car in an unheated attached garage in Michigan. Temps inside the garage rarely dip below freezing although it happens occasionally.
I store the car with cold tire pressure at 38 lbs.
The key is to NEVER move the vehicle while in winter storage.
This seems to have worked for me.
Most summer performance tire manufacturers recommend allowing the tire temperatures to rise above 40 degrees for at least 24 hours before moving the vehicle.
I ran street legal R compound tires on my C5 Z06 for many years and never had an issue with tires cracking following this protocol.
Tyrolblue67
Tyrolblue67 is offline   Reply With Quote
Old 07-08-2020, 11:05 AM   #36
Rodan
It's not just damage you need to worry about. I have experienced significant performance degradation on R comp tires that were stored in conditions that went under 30*F. No actual damage, because they weren't moved at those temps, but no grip when they got back on track in spring.
Any R comp tire (including SC3Rs) should not be exposed to temps under freezing, and will likely suffer damage if the vehicle is moved on them under those conditions.
Just my experience. All my track tires spend the winter inside now.
Old 07-08-2020, 06:55 PM   #37
Tyrolblue67
That's interesting. I never road raced my Z06. I couldn't get the car to hook up in straight line pulls until I went with the R compound tires. They seemed to keep that ability for the three years they were on the car.
I went with Michelin Pilot Sport 4s summer tires on my ZL1. They aren't R compund so hopefully they won't be damaged sitting in my garage during winter storage. Hooking up a ZL1 is quite a challenge. Not a bad problem to have. This car is in another league!
Thanks for the info.
Tyrolblue67
Old 08-04-2020, 09:17 AM   #38
ZL1 affair
ZL1 affair's Avatar
Wanted to update this thread.
GM warrantied all four tires, life is good!
[IMG][/IMG]
Old 08-04-2020, 09:28 AM   #39
BlueinTN
Drives: gas powered
Originally Posted by VinnAY View Post
*normally* there's a tire warranty supplement in the glove box with the manual that says the/any tire warranty is the tire manuf problem.
I cant see it.
To me its an application problem. the tires were moved when cold and just like the manufacture suggested they cracked.
I mean I hope the OP gets new tires on his new car that are functional but its not Goodyears fault.
I bought my car because I knew it was on the showroom floor all winter nice and warm. Guess that makes me weird.
2018 ZL1 ZLE
Oldblueaccord <<< MY YOUTUBE PAGE!
BlueinTN is offline   Reply With Quote
Old 08-04-2020, 12:42 PM   #40
VinnAY
Drives: 18 1SS/1LE
Originally Posted by BlueinTN View Post
I cant see it.
Thanks for reading the thread.
Old 08-04-2020, 12:55 PM   #41
FH212
FH212's Avatar
Drives: 2015 Camaro Z/28
2015 Camaro Z/28 - Red Hot
1978 Trans Am Y88 Special Edition 400/4 speed
2001 Mecham Trans Am #3 - 7.0L LS1
FH212 is offline   Reply With Quote
Old 08-05-2020, 03:01 AM   #42
BlueinTN
Drives: gas powered
hey I realized, reading forums like these, that the first 50 years of my life I been taking personally responsibility for my actions way way to much and life to seriously.
2018 ZL1 ZLE
