06-13-2020, 09:38 AM | #29 | |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
06-13-2020, 09:45 AM | #30 |
Drives: 2019 1ss 1le, blue wrap Join Date: Aug 2017
Can someone explain the point he was making here? I don't do time trials,, what is "collision avoidance"?
By the way, this is also why, if you are being caught quickly, let the guy go. Here in this case I wasn't eating the guy up and had a few second half that was closing steadily but not massively. But last time I caught someone, in a quicker car but on a tire cool down lap, so fast over the course of my hot lap, the collision avoidance warning went nuts. I get that you were a little faster and qualifed higher, but when i start a lap with no car in sight in front and barely a speck by turn 7, by the end collision avoidance should not be freaking out into the last brake zone. |
06-13-2020, 10:01 AM | #31 | |
The latter can be a BIG issue as it may apply brakes if one catches another car say in a turn and then the system applies brakes due to proximity of another car, lack of brake application, closing rates, etc. That would of course cause an immediate and violent spin. So, any such system should be turned off completely for any track duty. The issue is that some manufacturers will not permit a complete disabling of their systems. That's why, some clubs i know will not permit such cars at their track events, unless a driver can prove a system can be completely disabled. I think (only an assumption) that he was a bit peeved the car in front of him didnt accommodate a quick pass. Perhaps directed at the driver he ended up colliding with. At time trials the cars are usually spaced out to allow uninterrupted fast laps as folks compete against a clock. But, in some situations the cars can get close to each other depending on rules, driver strategies (sometimes designed to mess with a start of a fast lap of a driver behind them, etc). |
06-13-2020, 08:01 PM | #32 |
Drives: '18 1SS 1LE Join Date: Sep 2017
If a line leaked there would be residual fluid on the car/wreck trailing back.
If it was an internal issue in the master cylinder/ABS module the fluid would not have leaked until the wheel assembly left the vehicle. And then there would be little chance the fluid would have left evidence trailing back on the car.
'18 1SS 1LE Black, PDR
06-13-2020, 10:36 PM | #33 | |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
https://www.camaro6.com/forums/showthread.php?t=558312 |
06-14-2020, 10:01 AM | #34 |
Very interested in finding out what did happen since I track my car a lot, but not going to guess. It may just be one of those freak one off brake problems. Hopefully we can get the investigation results.
I vaguely remember one case a few years ago where there was a brake failure on track and it was a stock setup. There was no crash thankfully. Can't remember the specifics and can't find that info anywhere now. The guy that got hit has said he didn't see anyone and had just started tuning into turn 10B and and then hit very hard on the passenger side. Looking at Coby's Shields' Camaro video (he won the event) you could be doing about 90-100mph at the point you hit the brakes for turn 10B at Gingerman.. (Coby's speedo is off due to 18" wheels) and he does have power mods so probably more speed than Sam. Coby's video coming into turn 10B is at 1:10 https://youtu.be/oC063Gr5pEs?t=71 Strange coincidence, Jackie Ding's track prep Supra also went off at this event and at the same turn, but that was overheating brake fluid he said after only 4 laps. |
06-14-2020, 11:59 PM | #35 |
Drives: 2SS 1LE Join Date: Oct 2011
Then you'd hook up suspect MC to a functional brake system and it wouldn't hold pressure, right?
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
06-15-2020, 12:44 AM | #36 | |
Also weird that another car would lose brakes in the same corner, at the same event. One lesson that can be drawn with zero doubt, is that many folks dont pay sufficient attention to importance of peripheral vision while on a race track. As in the guy who didn't see Sam coming on what looks like a venue with very good overall visibility. Thanks for attaching Coby's vid. A likeable young gun who is obviously very dedicated and serious about his hobby, incl prep effort. His driving skills are superb and his pace excellent! Highly recommend his YouTube channel. One could argue that his driving style is a wee bit on an aggressive side, but he has plenty of talent to make it work for him without missing a beat! As an aside, for anyone doubting how fast stock G3s are in capable hands, check his 1le VIR lap (he considers it a 1le track record on street tires running square 305 RE71Rs). Then check Provoste's lap on stock G3s Anyhow, obviously i have a lot of questions, yet zero answers and won't stipulate what could have possibly happened to Sam's car. All i will say is that i am glad he is ok. Here's a pic of his LF wheel posted by member in the unrelated BMR thread (just to add some relative detail): |
06-15-2020, 12:48 AM | #37 |
06-15-2020, 04:23 AM | #38 |
Drives: Grandad's C2 L89 Join Date: May 2017
Following. Interested in the resolution to the issue.
I'm thankful that no one was seriously injured as a result of the aforementioned incident. While I would not consider the OEM brake lines (flex) on 1LE sub-standard for DD use, after changing out mine and getting a closer look, I personally would not trust them in any form of HPDE or semi competitive track event, let alone wheel to wheel racing. Crimping in the OEM line was decent as was design and execution. However, expansion and subsequent potential for fatigue as well as the possibility for damage from debris in the wheel well were a definite concern for me. A factory DOT3 fill in a track oriented car is a questionable decision in my opinion as well. Unless the thought process is to change out after break in. FWIW, I'm very satisfied with the performance of the OEM calipers and pads. Brembo in collaboration with Chevrolet did a great job. I've had no issues with my MC or ABS.... Power steering motor overheat in a high lat G turn can be an adventure though. Let's save that conversation for another day. Apologies for the rant.
2018 ZL1 1LE sw/PDR
06-15-2020, 09:25 AM | #39 | |
Drives: gas powered Join Date: Jan 2019
Still sounds like ABS issues or failure. There plenty of youtubes out there of problems with the moduals. Older Fords there is a recall. Sorry I triggered with the ice mode comment I use that as a term for ABS issues. Could be as simple as air in the ABS system or incompatible fluid. Machines fail despite the best design. I work on multi million dollar ones everyday and nothing really ever surprises me. The printing press I work on was 11 million dollars in 2003. Just to complete the circle I didnt have an airbag or ABS car until 5 years ago. Never had any faith in them esp airbags designs which sadly I was correct on. I have had a "no throttle response" on my SRT Jeep several times,one I just missed getting rearend. The shifter "slipped" out of Park 2 or three times. I just dont have full faith in automotive designs. It is what it is. Hope he gets it resolved and glad he came out ok.
06-15-2020, 11:25 AM | #40 |
side story .... Jackie loses brakes goes off at 10B and almost starts a fire. Learns he should have a fire extinguisher in his race car the hard way. He switched to SRF, not sure what he had before.
https://youtu.be/FpkfMF_quBI?t=8 |
06-15-2020, 11:26 AM | #41 | |
What volumetric expandability tests have you performed between OEM lines and aftermarket ones? And which aftermarket lines specifically? What stress tests have you performed to lead you to conclude there is a possibility of fatigue and failure re: OEM lines? What lines have you purchased to replace your OEM lines? From what i understand, OEM lines are official low expansion spec with double rayon layer. New gen rayon was invented in 2012 which offers superior low expansion qualities. I am all for more safety especially when braking systems are concerned. At the same time, i am a wee bit concerned with a possibility of some SS lines being manufactured in somebody's "garage" vs OEM facility. That's not to suggest all of them fall into this category. Cheers! |
06-15-2020, 11:28 AM | #42 |
