Old 06-10-2020, 09:25 PM   #29
95 imp
Dumb Ass Deluxe
Bend over and say "AHHHH!" That sounds a "little" extreme...
Old 06-10-2020, 09:59 PM   #30
puppykat33
puppykat33's Avatar
Drives: Black 2019 ZL1 M6,
doubtful. considering 1LE average time of ownership, 2 oil changes a year saving $40 each time, it would take 3-4 years to recoup that money. and lets be honest, odds are... the car will be long gone by then and the owner will have already purchased a camry or volt or something.
unless he is a one vehicle owner and dosent plan on doing his diff service himself . the ramps will pay for them self
2019 Black ZL1, M6, CF Hood and Dash, Nav System, ZL1 Addons rock guards and lift points, Michelin Pilot Sport 4S, DD Smoked Marker Lights, Ceramic window tint, Gtechniq 9yr ceramic coating. JL Audio stealth box 12W6, Dyanamat trunk, Dead pedal cover, Soler TB/TC, Green Filter, Carbon-fiber Borla S-Type
puppykat33 is offline   Reply With Quote
Old 06-11-2020, 04:44 AM   #31
cdrptrks
cdrptrks's Avatar
Originally Posted by MANNAXMAN View Post
I picked up a pair of Rhino Ramps from Home Depot for about $40+tax a couple of years ago. They work fine for doing oil changes.
Unfortunately the front splitter of the SS 1LE doesn't clear these ramps. I already had them when I got my car and it clears with 2 RV leveling blocks in front or a short section of board would work. I zip tied them together and put a bolt in the front middle with hot glue to align with the rhino ramps hole to reduce the chance of them sliding forward/backwards but it is still a good idea to drive slowly especially when backing off of the ramps.
Since they are removable I can still access the front pinch welds to jack the car up while it is on the ramps which is nice. Zl1addons jack pads or something equivalent is highly recommended to prevent bending/flattening the pinch welds when using a jack on them.
Old 06-11-2020, 07:37 PM   #32
Homer2
Homer2's Avatar
Drives: 50th Anni.. coming home 11/01
I pay an average of 85-100 pre-tax.. Canadian for an oil change. No way you should be more.
Built Sept 16/2016 - #2681 of 5955. She came home with me 11/01/16. 50th Anni, 2SS, A8, NPP, NGM Rock Guards, Footwell Lighting, Black Bow Ties, Street Warrior Rotors and Pads, Ceramic Pro, 3M PPF, Oracle Ghosted Side Markers, Kooks 2" headers w/hi flow cats. GPI Stage 1 Cam installed at 305,000 kms.
Homer2 is offline   Reply With Quote
Old 06-11-2020, 09:15 PM   #33
Chutzpah
Chutzpah's Avatar
Drives: Wild Cherry LT1
12 quarts Mobil 1 ESP = $101 /12 * 10 ~ $84 for an oil change. Then add filter $5... so ~ $90 to change my own oil, with race ramps. Not cheap.
Old 06-11-2020, 09:24 PM   #34
Aragorn
Drives: Camaro SS 1LE
Originally Posted by Chutzpah View Post
12 quarts Mobil 1 ESP = $101 /12 * 10 ~ $84 for an oil typical oil change. Then add filter $5... so ~ $90 to change my own oil, with race ramps. Not cheap.
The alternative would be to buy the Costco brand.
2.50 for 5w 30
Aragorn is offline   Reply With Quote
Old 06-11-2020, 09:28 PM   #35
Chutzpah
Chutzpah's Avatar
2.50 for 5w 30
Yea, there are a lot of good oils out there, on the cheap..I use them in my other vehicles.
I’d hate to lose the warrant on this one, so it is what it is until it’s up...
Old 06-11-2020, 09:57 PM   #36
caSStro18
Drives: 2018 Camaro SS
The Costco brand (Kirkland) is DEXOS Approved Gen 2. Your warranty will be fine. The manual just states that the oil should be DEXOS Approved. That’s all. But, it’s not my money so you have to do what you are comfortable with. That’s what matters the most I guess.
caSStro18 is offline   Reply With Quote
Old 06-11-2020, 10:07 PM   #37
Chutzpah
Chutzpah's Avatar
I’d be comfortable if Kirkland had 0-40 dexos 2 oil... I’m pretty certain they don’t and that’s required to be used in my 2019 Z.
Old 06-11-2020, 10:44 PM   #38
caSStro18
Oh, I just realized you don't have an SS. Sorry.
Old 06-12-2020, 12:18 AM   #39
2SS Capt
2020 Shadow Gray 2SS
2SS Capt's Avatar
"Dexos Gen 2" is NOT "Dexos 2"... Dexos "Gen 2" is actually "Dexos 1, Gen 2"... Definitely NOT 'Dexos 2"....
Old 06-12-2020, 01:29 AM   #40
caSStro18
Yes, but the SS does not require DEXOS 2 though. The manual states DEXOS 1 Gen 2. Sorry , I guess I should have been more clear. It’s kind of confusing really.
Old 06-12-2020, 06:35 AM   #41
s346k
s346k's Avatar
Drives: like an old lady
last time i got a blackstone report it did not list whether or not the oil was dexos 2, dexos 1, dexos 1/2 or 1st generation dexos 1, second generation dexos 1 or even why my phone keeps correcting dexos to sexist.
Old 06-12-2020, 07:02 AM   #42
JT58
Drives: Former 2016 Camaro 1LT
Wow, $141.00 seems expensive yes but actually not that bad for full synthetic and I am assuming 8 quarts?
As already stated it's easy to do yourself but not for everyone. You need to know the jacking points, have jacks, jack stands, or ramps (but they are hard to drive on). And of course tools to remove the drain plug and oil filter. And you cannot over tighten the oil filter or drain plug either.
You can get the oil at Walmart or order it on line- so many brand choices available- it's preference. And I order my oil filters from Rock Auto. I buy multiple at a time and for my other cars to offset the shipping.
It is definitely cheaper to do oil changes yourself- and once you have the tools and jacks, etc. you can do oil changes forever and on any cars or trucks.
2006 C6 Corvette Manual, 2019 Silverado, 1997 Jeep Wrangler
JT58 is offline   Reply With Quote
