Old 05-14-2020, 09:24 PM   #29
Jbanta1983
Drives: 2019 2ss 1LE
Too rich down low then too lean up top. I wouldn't run it hard until you get it tuned properly.
Copy
Jbanta1983 is offline   Reply With Quote
Old 05-16-2020, 08:32 AM   #30
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by Jbanta1983 View Post
After installing brand new wideband sensor and moving the sensor upstream of the cat I'm reading around 13 at WOT and 15 cruising. Procharger wants me ti take it to a dyno and log it which I'd have to pay for, then send my ecm back to them to retune it. All dynos near me are booked 5 weeks out. My question it's is it possible my wideband reading is off? How else can I tell if I'm running lean? Look at the spark plug? I'd like to verify this number is correct somehow before I go thru this hassle. If I switch to lambda will that do anything? By ther way the car seems to be running great, it rips hard
Good Morning Jbanta1983, I can help you, I have tune hundreds of Procharged Gen6 Camaro remotely and on my Superflow dyno.
Give us a call 203-753-7223
www.jannettyracing.com
email tedj@jannettyracing.com
Old 05-16-2020, 08:53 AM   #31
Jbanta1983
I have a feeling there is a leak where they welded in thve bung for the 02 sensor sho I got some jb weld exhaust sealer and put it around the weld, I also dropped the cat and made a new gasket incase anything was getting thru there. Taking it for a ride around noon hopping for better results.
Old 05-16-2020, 08:55 AM   #32
Jbanta1983
Thanks for reaching out ted..at this time I don't have hptuners I'm hoping to Get a safe tune from procharger cause I already paid them for it. If this doesn't work I will reach out to you.
