Old 05-08-2020, 11:09 AM   #29
Redlinez
Shifts under load
Redlinez's Avatar
Originally Posted by EWard View Post
I have the 1.5 ton HF not very impressed seems like it struggles with the weight. Costco has a great deal on the Arcan 3 ton jack for $119 and if is a night and day difference in use and quality.
https://www.costco.com/3-ton-profess...100222458.html
Thanks! That one lifts to over 18". That's great!
22 Suzuki GSX-S 1000GT blue
Old 05-08-2020, 01:45 PM   #30
ctrlz
This is what I use. Price is without the mandatory 20% coupon.
https://www.harborfreight.com/3-Ton-...ack-64264.html
Old 05-08-2020, 02:18 PM   #31
DIYguy
DIYguy's Avatar
Drives: 2017 Camaro 1LT
^^ Yep, a pair of those would be quite nice.
I bought my smaller jacks, one more than 10 years ago when the 3 ton versions were still hideously expensive.
Then I bought the second one about 3 years ago when I bought the Camaro.
It was the "same" model as the older one, sort of.
If I were to replace them today I would definitely buy the 2 ton versions or larger.
I did have a problem with the newer 1.5 ton jack when its side panels warped.
HF had cheaped out the model with thinner sides than the original one I had.
So I made new side panels from thicker material (still aluminum) and now it works great.
I complained rather bitterly to them and of course I got absolutely nowhere.
At least with Costco they do stand behind their products with generous return policies (except for returning toilet paper these days of course).
Caveat Emptor.
Gen6 Camaro LT (my daily driver), Cruze ECO (grocery getter), Chevy SS Pickup (wife's daily driver), Honda Shadow, Honda CBX
DIYguy is offline   Reply With Quote
Old 05-08-2020, 02:42 PM   #32
L8Apex
Drives: 2016 2SS
I'm almost 100% sure that Costco jack is the same one I bought at Sears a few years ago, it's been a good one though.
I think just about all brands are made in china anymore.
L8Apex is offline   Reply With Quote
Old 05-22-2020, 01:30 PM   #33
Wiskey
Drives: 2016 Chevy Camaro
I ended up getting jack stands with stand pads that go over the pinch point, and a floor jack with a pad as well. It worked great! Thanks everyone.
Whiskey
Wiskey is offline   Reply With Quote
Old 02-23-2023, 03:14 PM   #34
Canyonero
Canyonero's Avatar
Drives: F-Series Canyonero
Is there any concern about getting all the oil to drain on ramps vs level?
Canyonero is offline   Reply With Quote
Old 02-23-2023, 05:13 PM   #35
ZPirate
ZPirate's Avatar
No. Not for me. I've been using Raceramps for years to change the oil in multiple vehicles with no issues. If the drain plug is near the back of the oil pan ramps probably allow more oil to drain from the pan than if the car is on a flat surface.
2003 Nissan 350Z (modified)
2009 BMW 135i (Sold)
Old 02-23-2023, 05:54 PM   #36
Canyonero
Canyonero's Avatar
Great, this makes life a lot easier
Old 02-23-2023, 05:56 PM   #37
JTS
JTS's Avatar
Drives: 2023 ZL1 A10
Raceramps are expensive, but worth it IMO , the 2 piece , I'm going to purchase these.
2023 ZL1 A10 Shadow Gray Metallic
JTS is offline   Reply With Quote
Old 02-23-2023, 07:03 PM   #38
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
Race ramps are what I use.
Old 02-23-2023, 07:20 PM   #39
SSEssence
Instagram: Sangstah
Drives: 2019 Camaro 1LE
Harbor freight low pro Daytona jack, with jack stands and ZL1addons jack pads!
SSEssence is offline   Reply With Quote
Old 02-23-2023, 07:35 PM   #40
Big Lou 1le
Big Lou 1le's Avatar
Drives: 2023 1le
What size are these? Trying to get some for my SS 1le.
Big Lou 1le is offline   Reply With Quote
Old 02-23-2023, 08:53 PM   #41
ZPirate
ZPirate's Avatar
I agree. The two piece ramps are the way to go. Once you have the vehicle on top you can remove the lower part to allow access under the sides of the vehicle. I also have the heavy duty ramps, rather than the basic ramps, so I can use them on my SUV too. Each ramp can support up to 2,500 pounds
Old 02-23-2023, 08:55 PM   #42
ZPirate
ZPirate's Avatar
Mine are the 67 inch two piece heavy duty version.
