Old 03-10-2020, 01:39 PM   #29
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
What's the concern?
Stabilitrack will think your front tires are traveling 10% faster than your rear tires. Not sure what effect it will have, that's why i'm interested.
Old 03-10-2020, 01:44 PM   #30
TheRealJA105
Drives: 2013 C6Z06
Originally Posted by TheRealJA105 View Post
Following to see if this MASSIVE 2.34" tire diameter difference renders your car unmovable or not.
What's the concern?
Actually tire rack says the fronts will be 2.6" shorter. I screwed up my math the first time because calculating it out i got 2.58".
Old 03-10-2020, 01:48 PM   #31
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
Originally Posted by Markoz28 View Post
A 295/25/19 is a very thin/short tire. Not sure why you would want that?
The Viper ACR uses it, does quite well at the track... I have what I call play tires I stick on friday just before I leave work at 11 30 am... Then monday I take them off and use my DD tires. I can drive on the play tires no problems just prefer not to..
I was talking to a die hard road course guy he swears by them best grip ever!
Plus the 295 25 19s are 180.00 No where in hell can you get a Street/track tire for that..
So I run a 345 30 19 Toyo in rear and the 295 25 19 in front...
Soon as the toyo r888r are done it will be 355 30 19 Viper ACR tire V720 kumho in the rears..
Just a lower profile stiff side wall.. slightly narrow from 305s
Old 03-10-2020, 01:58 PM   #32
TheRealJA105
Drives: 2013 C6Z06
The Viper is calibrated for the tire diameter difference!!!
My math wasn't off, I originally calculated off of your 345s. That makes more sense now.
Old 03-10-2020, 02:12 PM   #33
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
The only time stability trac went off was running 275 40 20 and a 325 30 19 both on the back.. Flat tire and someone had to saved me..
It acted like cruise control was on and the car revved by itself lol
Old 03-16-2020, 12:37 PM   #34
gotswap
gotswap's Avatar
Drives: 2019 ZL1 Crush
new shoes have arrived!!!
2019 Crush A10
E-Force 2650
670WHP 615WTQ
All besides the 2650 is bone stock down to the air filter.
gotswap is offline   Reply With Quote
Old 03-17-2020, 07:00 AM   #35
Fredtp
Fredtp's Avatar
Drives: 2019 ZL1 A10 Black Mosaic
Are those BC Forged Brushed Black Dark?
2019 Black Mosaic ZL1 A10
Kong Ported SC, 2.3 Grip Tec, Roto-Fab Big Gulp, NW103 TB, Mighty Mouse CC, ADM Expansion Tank, ARH 1 7/8 Headers, Catless 3" X-Pipe, Corsa Extreme, Eibach Springs, BMR Cradle Lockout, BMR Trailing/Control arms.
Fredtp is offline   Reply With Quote
Old 03-17-2020, 07:11 AM   #36
Swoosh_ZL1
Swoosh_ZL1's Avatar
Drives: 2018 Camaro ZL1 (M6)
Congrats, great looking wheels!
Swoosh_ZL1 is offline   Reply With Quote
Old 03-17-2020, 07:14 AM   #37
gotswap
gotswap's Avatar
BC Forged, gloss black
2019 Crush A10
E-Force 2650
670WHP 615WTQ
Old 03-17-2020, 07:17 AM   #38
Fredtp
Fredtp's Avatar
What sizes and offset did you get?
Old 03-17-2020, 07:29 AM   #39
gotswap
gotswap's Avatar
20x10.5 20mm offset front
20x11.5 48mm offset rear
Did a test fit last night without rubber and it seems to clear everything perfectly. Will see once I get rubber on them this week.
2019 Crush A10
E-Force 2650
670WHP 615WTQ
Old 03-17-2020, 07:38 AM   #40
Fredtp
Fredtp's Avatar
What size and type tires you putting on them?
I to was looking at BC wheels in same size.
Old 03-17-2020, 07:51 AM   #41
gotswap
gotswap's Avatar
Stock size for now, will eventually go 295/315
Advan V601's
2019 Crush A10
E-Force 2650
670WHP 615WTQ
Old 03-17-2020, 10:29 AM   #42
Fredtp
Fredtp's Avatar
295 and 315 is what I was thinking also.
