Old 01-16-2023, 01:40 AM   #29
dynawide100
Dynawide100
dynawide100's Avatar
Drives: 14 Camaro 2SS,L99, CAI intake, kook
Oil Pump issue
I have a 2018 ZL1 and have been searching/trying to find out where to verify if my oil pump has been changed (by VIN#). Is there a website that I can go to for verification? Is there a manufacture date timeframe that I should be looking at? I would appreciate any assistance to steer me in the right direction.
dynawide100 is offline   Reply With Quote
Old 01-16-2023, 04:10 AM   #30
Z OH 6
Drives: 2024 CT5-V Blackwing
If the dealer changed it, it should be in their database. Check with a Chevy dealer.
Old 02-08-2023, 01:03 PM   #31
2023ZL1
BLACK 2019 ZL1
2023ZL1's Avatar
Drives: 2007 COBALT, 2019 CAMARO ZL1
I WORK AT GM AND THE OIL PUMP LISTED FOR 17-21 IS DIFFERENT THAN 22-23.
2017-2021 OIL PUMP# 12686434 AND OIL PAN ASSEMBLY# 12639931
2022-2023 OIL PUMP# 12698353 AND OIL PAN ASSEMBLY# 12696684
IM STILL LOOKING INTO THIS FOR MORE INFORMATION.
2023ZL1 is offline   Reply With Quote
Old 02-08-2023, 02:42 PM   #32
Katech_Zach
Katech_Zach's Avatar
Drives: 14 Camaro SS 1LE
I believe there are 9 iterations of the same pump for Gen6 Camaro. Minor changes in all, and improvements as they get newer, but the newest ones can still fail (although less likely).
Katech_Zach is offline   Reply With Quote
Old 02-08-2023, 02:50 PM   #33
taylorforschool@gmail.com
PKG4U
taylorforschool@gmail.com's Avatar
Drives: 2018 ZL1
9….lol. You’d think if they put a little more effort into #2 or even #3.. there wouldn’t be a need for 9.. lol Gm
2020 Camaro LT1. Bought 10/2020 | GM PERF. CAI | GM Muffler Delete (Performance Exhaust 4” tips). | SOLD 1/2022|
2018 ZL1 Summit White | Bought 1/2022 | PDR, Recaros, Carbon Dash, WeaponX Hx System, Apex SM-10 in ZLE fitment w/PS4S
Mods after Warranty “Imma keep it stock”
taylorforschool@gmail.com is offline   Reply With Quote
Old 02-08-2023, 03:01 PM   #34
2023ZL1
BLACK 2019 ZL1
2023ZL1's Avatar
17-21 NUMBER IS CURRENT AND GIVES AN OLDER NUMBER BUT IT HAS NO CORRELATION WITH THE 22-23 LISTING AND IT'S PRIOR NUMBER.
WISH THEY JUST MADE IT CLEAR.
Old 02-08-2023, 03:52 PM   #35
ZX-10R
ZX-10R's Avatar
Drives: 2019 ZL1 Riverside
+100
ZX-10R is offline   Reply With Quote
Old 02-08-2023, 05:35 PM   #36
ramair00
Drives: 2017 ZL1 Coupe White A10
So if I get my pump replaced at dealership, I should be getting the latest version regardless of part number?
ramair00 is offline   Reply With Quote
Old 02-08-2023, 06:31 PM   #37
PKG4U
Drives: 2018 ZL1
Honestly, I’m sure it depends on the dealer. But I would suspect they will cram whichever one they see fit in there. With the latest part being the most likely and logical option
Old 02-08-2023, 06:53 PM   #38
2023ZL1
BLACK 2019 ZL1
2023ZL1's Avatar
CALLED GM CANADA, NEW NUMBER FOR 22-23 WILL NOT FIT 17-21, COULD BE THEY DIDN'T WANT TO GO INTO IT, OBVIOUSLY ENTIRE PAN ASSEMBLY WOULD ALSO NEED TO BE CHANGED AS WELL. BUT SIMPLE ANSWER WAS NO IT DOES NOT FIT ON YOUR 2019 ZL1. AS FOR WHY IT CHANGED UP I'M NOT SURE, COULD BE A SEAL WAS REDESIGNED OR SUPPLIER CONSTRAINTS OR MATERIALS.
I'M JUST GOING TO GO WITH THE KATECH UPGRADED PUMP IF MINE FAILS, I BABY MY CAR AND DO PROPER WARM UP BEFORE DRIVING IT. MOBIL 0W40 DEXOS R OIL AND CHEVRON 94 OCTANE FUEL (CONTAINS NO ETHANOL) AND I DON'T TRACK THE CAR.
Old 02-08-2023, 10:26 PM   #39
ramair00
Dealership here would not even perform the work if I wanted to install my own purchased ktech.
Warranty issues.
Old 02-09-2023, 07:31 AM   #40
ParisTNDude
Owning SSes for 50 Years
ParisTNDude's Avatar
Drives: Sharkskin Grey LT1
I had reduced or no oil pressure due to the grommet between the pan and block. It cost me a fortune to fix it even though it should have been a warrant item. Oh, well it's only money.
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars:
1966 Chevelle SS 4M, 2010 Corvette 6M
1968 Dodge Charger R/T Auto 2012 1SS 6M
1982 Corvette Auto 2010 1SS 6A
1984 Corvette Auto 2016 2SS 8A
1999 Camaro Auto 2017 HBM 1SS 1le
2002 C5 Corvette 6M 2018 2SS
2006 Corvette Auto 2023 Camaro LT1
ParisTNDude is offline   Reply With Quote
Old 02-09-2023, 08:31 AM   #41
gblaue
gblaue's Avatar
Drives: 2017 Bright Yellow ZL1 6spd
Warranty issues.
My local dealer tried to pull the same thing. I said, "Let me get this straight, You won't install my Katech pump, and you want me to pay $3500 for the same oil pump that will fail again because GM will warranty it for 2 years?"
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
gblaue is offline   Reply With Quote
Old 02-09-2023, 09:48 AM   #42
Okay, so what's that supposed to mean? GM fixed the pump but doesn't allow the part to retrofit?? My common sense dictates that they didn't fix anything substantial and it's just some fitment or clearance change.
