Old 04-09-2020, 01:52 PM   #29
Redlinez
Shifts under load
Redlinez's Avatar
I used the Redline stuff with no issues, but I didn't notice an improvement, so next time I may go with GM or GM Synchromesh.
22 Suzuki GSX-S 1000GT blue
Old 04-23-2020, 01:38 AM   #30
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
if going with Amsoil go with Torque Drive
Old 06-11-2023, 03:06 PM   #31
lamp210
Drives: chevy camaro
hello everyone i have been reading all these posts about the tranny fluid so with that said, i have a new 2023 zl1 with 2000 miles on it ok it shifted pretty well with the oem fluid in there but i changed all three fluids read diff motor and tranny so in the tranny i went with the termec HP-MTF and it seems to be worse as far as being notchy and hard to get in 1st 2nd when cold i live in a colder climate (upper northern Michigan)i dose seem to get better when fully warmed up bit it takes along time to get there i am thinking on trying amsoil as i have had good luck with it in other applications. just my 2cents.
lamp210 is offline   Reply With Quote
Old 06-11-2023, 09:35 PM   #32
wakespeak
wakespeak's Avatar
Drives: 2020 ZL1 1LE
yep the HP-MTF is a thicker spec than Dexron III/GM manual transmission oil. Will not be as easy to shift in cold weather. I would switch back unless you're running your car at the track.
wakespeak is offline   Reply With Quote
