Old 09-09-2020, 12:25 PM   #29
Magnum922
Magnum922's Avatar
Drives: 2017 Camaro 2SS, A8
I have 4850 miles on it now. Still no shutter problems.
Magnum922 is offline   Reply With Quote
Old 09-09-2020, 07:16 PM   #30
ctrlz
Originally Posted by Magnum922 View Post
I have 4850 miles on it now. Still no problems.
Cellsafe is right. Get the fluid swapped before you have problems.
Your car came from the factory with a defective part... that just happens to be poured out of a bottle.
Old 09-09-2020, 08:31 PM   #31
Magnum922
Magnum922's Avatar
I got mine flushed at 4000 miles early 2020.
Old 09-09-2020, 11:28 PM   #32
Haoie
Drives: 2017 50th Anniversary SS
Had it done at 25,991 miles back in March and now I'm feeling it again over at 29,464. I'm also getting very hard shifts when just cruising. At this point I feel like the torque converter is done for but the dealership might do a fluid flush for the second time
Haoie is offline   Reply With Quote
Old 09-09-2020, 11:48 PM   #33
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC
Originally Posted by cellsafemode View Post
if all that happened before the blue label fluid in early 2019, then I'd still get new fluid put in now before any kind of shudder symptoms show up.
I'd really suggest absolutely everyone with the A8 (and even early A10's) get all new fluid put in if it has fluid from before the 2nd quarter of 2019. Regardless of symptoms.
You really dont want to wait for the issue to get bad enough to cause shuddering before dealing with it.
Good call. When I take it in, what do I ask for to make sure I get the newest fluid?
Mobil 1 Blue?
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie!
___________________________________________
Ordered from GM
Delivered to dealership and home 9-16-16
This car is a beast!
PnCRedJwl2SS is offline   Reply With Quote
Old 09-10-2020, 09:43 AM   #34
OB0001
OB0001's Avatar
Drives: 2018 Camaro SS A8 "Dark Knight"
I have a 2018 SS A8 no shutter
DARK KNIGHT
2018 SS A8 11.37 @ 121.01 GPI Tuned E85 Nitto tires Roto Fab CAI MSD intake
OB0001 is offline   Reply With Quote
Old 09-10-2020, 07:39 PM   #35
Need4Camaro
Drives: '17 Camaro 2SS & '99 Camaro Z28
Mine had the shudder around 29k miles, they did the flush and it came back at 61k miles, literally 1k miles outside of warranty. They had to replace the converter and do a tune on the second attempt. Costed $2,700 ... good thing I kept my extended warranty.
Need4Camaro is offline   Reply With Quote
Old 09-10-2020, 11:10 PM   #36
cellsafemode
cellsafemode's Avatar
Drives: 2016 Camaro 1LT
Mobil 1 Blue?
Yeah. Mobile 1 didn't change the name of the fluid. The only way to really identify good vs bad is the blue label vs black label.
Old 09-11-2020, 03:42 PM   #37
classicrockr
Pills are for Pansies
classicrockr's Avatar
Drives: 2023 2SS Red Hot Vert Camaro
Had fluid change done recently at 73k miles. Extended warranty didnt cover it because there was no metal flakes in the fluid. Its better now but shudder is present at low speeds (20-25mph) in the 100-1300 rpm range. Its fine cruising at speeds above 40mph. Today i did notice its jerking some between 1st-2d gear.
classicrockr is offline   Reply With Quote
Old 09-12-2020, 04:23 PM   #38
TTown918
TTown918's Avatar
Drives: 24 ZL1 (4Runner, CRV, Civic, Expl)
That A8 is a dandy. Well done GM.
TTown918 is offline   Reply With Quote
Old 09-14-2020, 10:43 AM   #39
ctrlz
It's the fluid. This thread goes into the mechanism of the problem. Posts 15 and 17 are highlights:
https://www.bobistheoilguy.com/forum...issues.303084/
Old 09-14-2020, 12:46 PM   #40
Magnum922
Magnum922's Avatar
Is this it?
Old 09-14-2020, 01:00 PM   #41
ctrlz
Part number here:
https://gm-techlink.com/?p=11127
That bottle in your post does not have the blue banner.
Product name is: Mobil 1 Synthetic LV ATF HP
Old 09-14-2020, 04:30 PM   #42
PnCRedJwl2SS
Howdy! Pete here...
Excellent, thanks!
PnCRedJwl2SS
Ordered from GM
