03-22-2020, 10:59 AM | #29 | |
Drives: The DSSV Twins: ZR2 and ZLE A10 Join Date: Oct 2019
Would the camber plate rotation get the ZLE close to -2.7 front? |
03-22-2020, 12:14 PM | #30 | |
Drives: 19' ZL1 Join Date: Feb 2020
https://www.gmpartsdirect.com/ Used Part Numbers: Rear Camber Bolt: 11547215 Rear Toe Bolt: 11611276 From this thread: https://www.camaro6.com/forums/showthread.php?t=502324 You can easily get -2.7 on the ZLE but its a combination of camber plate rotation and then fine tuning. Unfortunately you can't just rotate camber plates for the track as adding camber also affects the toe settings. |
03-22-2020, 03:32 PM | #31 | |
