Old 01-03-2020, 09:16 AM   #29
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by KPzypher View Post
Thanks. I guess stock fuel system is kinda pushing it on the low 600s range without E or meth setup?
580 RWHP is pushing it on stock fuel system.
With an LT4 fuel system upgrade and E60. you can make 650 RWHP reliably.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 01-03-2020, 10:20 AM   #30
laynlo15
Drives: 2022 Lt1 A10
That works also.
Old 01-03-2020, 05:20 PM   #31
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Ted.
What would be the RWHP and PSI Boost limits on an SBE LT1, Stock C/R when utilizing LT4 fueling on 93 straight without E?
Old 01-03-2020, 07:13 PM   #32
danhr
BAMF SS
danhr's Avatar
Drives: 2016 Camaro 1SS A8
Send a message via AIM to danhr
I maxed mine out at 11 psi at 600 rwhp on lt4 fuel syste.
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock
800 SAE rwhp. 9.4 @ 145 mph.
Old 01-04-2020, 07:16 AM   #33
JANNETTYRACING
Fuel quality is the big variable, 93 is not always 93 and could have different levels of ethanol which reduces detonation.
I have been 620 RWHP no where near the fuel system limit with Octane being the limiter on the LT1
The other big variable is the supercharger and intercooler system being used there is a difference.
Boost is not created equal.
We have seen cars make 50 more HP at .5 psi less boost with the TVS 2650 Vs. other superchargers.
Ted.
Old 01-04-2020, 02:20 PM   #34
Eldi Z
Was this running 93 straight, no E content at all?
You reached 600 RWHP at 11 PSI?
Seems quite a high level of boost for such RWHP figure....
Old 01-04-2020, 02:25 PM   #35
Eldi Z
Ted.
Thanks Ted. Long term timing advance is probably a critical factor in achieving the higher RWHP figures... Detonation is the "danger" - Needs an expert tuner to know where to draw this fine line. I guess that factors like Injector ms. times also play a vital role?
Do you have experiences using the LT4 TVS Eaton 1750 on a stock LT1?
If so, which kind of boost levels did you run it optimally on 93 and which kind of max. "safe" RWHP did you see with such optimal boost levels?
Old 01-04-2020, 09:47 PM   #36
danhr
BAMF SS
danhr's Avatar
Correct. Straight 93 (well the usual 10% ethanol)
It was a pretty conservative tune. Just used it to ball park the tune before the meth got turned on. Ended up at 760 rwhp
Stock Longblock
Old 01-05-2020, 01:19 PM   #37
Eldi Z
OK and what do you think you would have achieved with your tuner at say
8 PSI without Meth? Safely!
Old 01-05-2020, 01:57 PM   #38
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
That is odd. Only 600whp @ 11 psi. Must of had a bunch of timing pulled?
Old 01-05-2020, 07:09 PM   #39
Eldi Z
Exactly what immediately came to my mind.
After-all, we are talking 93 here (and not 91)...so I would expect this power level to be safely achieved already at 8.5-9 PSI max...
Old 01-05-2020, 11:47 PM   #40
oldman
Drives: SS 6 speed of course
I would go lt4 injectors, lpe high pump, zl1 I tank, voltage booster for a 100 percent stock reliability. Still way within your budget. Count yourself luck that 93 is easy to get where u are.
Old 01-06-2020, 07:24 AM   #41
JANNETTYRACING
The TVS 1750 is extremely knock limited Not a fan.
Ted.
Old 01-06-2020, 07:36 AM   #42
JANNETTYRACING
We have many builds like this cataloged on our facebook video page have a look.
https://www.facebook.com/pg/jannetty...=page_internal
Ted.
