Old 11-19-2019, 08:45 AM   #29
blkbeauty16
blkbeauty16's Avatar
Drives: 2019 zl1
Originally Posted by Scottyz View Post
^^^ And your car is otherwise stock besides the tune, e50 and cai?
Yes nothing else done too it and it's also a m6 car.
blkbeauty16 is offline   Reply With Quote
Old 11-19-2019, 08:46 AM   #30
blkbeauty16
Drives: 2019 zl1
I was also on a Nitto 555r with 17 psi.
Old 11-19-2019, 08:54 AM   #31
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
Impressive. Even more so because it’s an M6.
Damn I wish I had taken mine to the track to get a baseline before our shit weather arrived
Old 11-19-2019, 08:57 AM   #32
blkbeauty16
Drives: 2019 zl1
I was pretty happy with the results. The 60 ft could of been better but I'm not complaining.
Old 11-19-2019, 10:18 AM   #33
17CamaroZL1
Life's Short, Live Fast!
17CamaroZL1's Avatar
Originally Posted by blkbeauty16 View Post
The best we could get it too go was 10.543 at 132.70mph.
car was running extremely hot on the supercharger temps so it was pulling 10 degrees of timing. thought it had air in the system so bleed it and still the same thing was beating my head with it. My son works for GM and was finally able too give me a had so he turned on the pump for the supercharger and nothing. We were going to check for power on the pump took my mirror to look for connector and it wasn't even plugged in. We plugged it in and it came on car took a quart and a half of coolant. The temps went down too 120. The car had a new bleeder valve put in by the dealer with 25 miles on it which I guess they never really did because there is no way they could of bleed the system with no pump. The car is currently on e50 and Cai and tuned by Pray.
A buddy of mine was at the track when you ran this and was telling me about it. Very impressive! Nice job!! You need to submit your slip for the bolt on list if you haven't already.
12/26/2016 Ordered!
2/8/2017 Built!!
3/2/2017 Brought Home!!!
Old 11-19-2019, 10:24 AM   #34
JonDaddy82
JonDaddy82's Avatar
Drives: 2018 ZL1 Coupe NFG M6
What size did you run? Great pass!
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School
2017 Colorado Z71 <- Daily
2018 ZL1 M6 <- Not Daily
JonDaddy82 is offline   Reply With Quote
Old 11-19-2019, 11:07 AM   #35
blkbeauty16
Drives: 2019 zl1
I have not summited it. I need too figure out why it's sideways first lol. Thank you also. I had a 16 ss with a P1x and thought that I had made the wrong decision going to the zl1.
Old 11-19-2019, 11:08 AM   #36
blkbeauty16
Drives: 2019 zl1
305/35zr20
Old 11-19-2019, 11:19 AM   #37
JonDaddy82
JonDaddy82's Avatar
305/35zr20
Old 11-19-2019, 12:41 PM   #38
17CamaroZL1
The sideways thing is nothing you did wrong. I don't know why, but everything I've ever posted gets turned sideways no matter what I do. I've even tried rotating the picture before uploading, thinking it would rotate and be right, but it looks the same way no matter what I do. One of the moderators can rotate it for you, but its not required.
I bet your SS would fly too. Was it also a manual?
12/26/2016 Ordered!
2/8/2017 Built!!
Old 11-19-2019, 01:18 PM   #39
Scottyz
Scottyz's Avatar
Regarding the sideways pics. What I do is edit the picture so basically I rotate it 360 degrees around!!! Yes the picture is upright again just like it was in the first place. Sounds stupid but it works for me. Then I will upload it to my post on here and when I post the picture it shows like it should.
I don’t know why this is or how to edit my picture after I have posted the picture, without deleting it and starting over again.
Old 11-19-2019, 05:22 PM   #40
17CamaroZL1
That is crazy, but I'll give it a try. The pics always seem to rotate a 1/4 turn counterclockwise, so I would rotate them 1/4 turn clockwise, thinking that would make them right once posted, but no.
12/26/2016 Ordered!
2/8/2017 Built!!
Old 11-19-2019, 05:34 PM   #41
I fix them all the time on here. It's the way the camera is held when taking the pic and there is no way to really fix it.
What I do is pull up the pic... rotate it and then use windows Snipping Tool to basically take a screen shot and save that as a different file to upload and I delete the original. It helps Merc not have too much neck strain..
Old 11-20-2019, 07:59 PM   #42
17CamaroZL1
So we should hold the phone in the widescreen/landscape position? I thought I had tried that without success, but maybe I'm wrong. Now I have 2 things to try. Thanks!
12/26/2016 Ordered!
2/8/2017 Built!!
