#29 |
Drives: 2012 45th SS Join Date: Sep 2010
Here shown into the factory NPP
#30 |
Zero modifications required to the factory hood on SS or ZL1 cars!
#31 | |
![]() Drives: 2017 Camaro 1SS Join Date: May 2018
This kit looks SPECTACULAR. Couple of questions: I own a 2017 SS, been building for track; suspension is great, but I will want more speed. I know it's probably too early to tell since your kit is still relatively new, but any projections of how this kit will do with prolonged application (not a 1/4 mile at a clip, but much longer/broader acceleration application)? In a non-ZL1 application, will we have to add forged rods and pistons to keep the motor from blowing up? Lastly, I may have missed it, but any dyno numbers on the LT-1? Thanks in advance, and congratulations on the kit. This looks great. |
#32 | |
LT1 results we will have very soon, but you can set it up to make as much power as you are comfortable with using the supplied wastegate spring options. Forged bottom end is not required unless you desire more power of course, but that goes with adding any type of power adder to these engines. |
#33 |
![]() ![]() ![]() Drives: 2016 Camaro SS Join Date: Sep 2018
What intake is that you are using for secondary port injection? Do you guys offer that intake with your kits?
#34 |
![]() ![]() ![]() Drives: 2016 Camaro 2SS Join Date: Apr 2018
That's the LME intake they are using. That intake alone is 4500 bucks but it sure is nice.
#35 | |
I am trying to sell my F1 Procharger kit and trying to determine if I should keep my Procharger intake or try and sell it all together and go with a different intake to run this turbo kit. |
#36 |
I would keep the procharger manifold if it was me. Once you start looking at intake manifolds from the likes of FED or LME your looking at a 4k minimum on top of the price of the turbo kit.
#37 | |
I think the MSD actually already has port injection bungs and it is just around $1000. |
#38 |
MSD is 2 piece and I would be concerned about it leaking under the amount of boost you plan to run. I say stick with the Procharger IM.
#39 |
Yeah that is my only concern as well. I will probably end up keeping the Procharger intake if I end up doing this, just waiting on someone to buy my Procharger kit now so I can.
#40 |
Drives: 2017 Camaro SS 1LE Join Date: Oct 2018
Will you be coming out with a larger IC that retains the front crash bar? I live in the desert where it is 110+ all summer, so I don't think I could get by with the half-blocked small one and I'm not at all willing to compromise the structural integrity of the chassis or my safety in the process.
#41 | |
#42 |
@viurniel
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT Join Date: May 2016
Goertz (G1Pro) had a sheet metal manifold on their site about two months ago- like the Procharger one - for less $$.
