Old 10-21-2019, 01:21 AM   #29
Giri
Soon to be Millionaire
Drives: Blue 2016 Camaro
Originally Posted by JCunningham View Post
o you have a V6. you have the 8l45 transmission. your 0-60 should be around 5sec.
Oops my bad I'm sorry I should have mentioned this earlier. I have the 4 cylinder LTG engine with the Automatic 8 Speed transmission
I run a Drone Service Company in Gainesville, FL - Please visit my site and take a look
Giri is offline   Reply With Quote
Old 10-21-2019, 09:05 AM   #30
Your factory 0-60 spec is 5.5 seconds, see below. If you're doing the run in sport or track mode and you definitely aren't spinning those all-season touring tires, the rest is probably due to the transmission. Again, the new flush, a new torque converter and a proper tune will most likely fix the shudder and make your launches faster.
Old 10-21-2019, 06:37 PM   #31
ZarusSS
Drives: Chevy Camaro
I just saw this comment in another thread quoting Al Oppenheiser
Based off of this comment shouldn't I be needing a TQ replacement anyways since I've driven multiple months on a badly shuddering transmission?
If it were me i would go with the Circle D
ZarusSS is offline   Reply With Quote
Old 10-23-2019, 11:45 PM   #32
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
Circle D told me $599 to rebuild mine in my 8l90e Silverado
