Old 06-10-2022, 09:08 PM   #29
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Originally Posted by ZL1Atlanta View Post
It is fine if you shift at a lower RPM. It's when you take it up to 6K+ and then shift during a burnout that really beats on them. I start in second, take it up just enough to get the tires turning, and then go to third to finish the burnout. It takes WAY too long to get a proper burnout in second gear.
I agree with that.
Old 06-11-2022, 12:06 PM   #30
cjperformance
cjperformance's Avatar
@KingLT1
Turns out the trans tune you helped me with already had the TUDU 2nd gear launch set up, but the shift points were too high for me still for 1-2 and 2-3. I assume because of my looser converter. So I just made the TUTD match what I had for WOT shift mphs and it works great!
DSX Aux Low Side | LT4 high side | Flex Fuel
TooHighPsi Port Injection (installed & tuning)
CircleD 3K Stall | QA1 CF Driveshaft
Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear
Forgestar F14 18x8 NT555G2 235/50/18 Front
10.84@131 w/4.13" pulley
??.??@??? w/3.7" pulley (installed & tuning)
Old 06-11-2022, 09:27 PM   #31
KingLT1
KingLT1's Avatar
Old 04-25-2023, 06:55 PM   #32
ZL1...SON
Drives: 2021 Camaro ZL1
I am curious about a couple things with this as I am starting to do some tuning on my 21 ZL1 A10. I have read in one place that both the RPM table and the MPH table have to be fine tuned due to it looking at both tables and both have to be satisfied before it will shift. I have read in this thread that the RPM table doesn't matter, and just the MPH table needs to be dialed in. Can anyone clear that up?
Anyone care to share their MPH tables? Currently I have my set to upshift at...
1>2 32mph
2>3 58mph
3>4 84mph
4>5 99mph
5>6 120mph
6>7 149mph
7>8 181mph
8>9 250mph
9>10 280mph
It'll be a couple weeks before I'm able to test those speeds, so I was hoping to get some input before I load it in hopes of skipping a little trial and error.
2021 Camaro ZL1 Satin Steel Metallic
Rotofab CAI, Banks Idash, AEM X series wideband, CSP 2" headers, Jet hot 2500 ceramic coating, DSX Flex Fuel Sensor, DMS Fender Tank, Velossatech Big Mouth, JMS Fuel Booster, MPI Billet Lid, Jokerz race port, 2.30" upper, 107mm Soler TB, 160°F Billet DMS, Big Gulp, LPE Big Bore HPFP, XDI +30, ECM & TCM tuned by Elite Tuned, BMR Cradle Lockouts, Atturo 315 AZ850DR
ZL1...SON is offline   Reply With Quote
Old 04-25-2023, 07:24 PM   #33
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
The TCM must see both conditions (MPH First, then RPM second) to be satisfied before commanding the shift. So, if you set the WOT MPH shift point, do so just before the RPM you want it to shift at, because of the order in which it works.
Old 04-29-2023, 05:05 PM   #34
ZL1...SON
Hmm. I loaded my tune and tried it out today but it did not appear to be following this logic. I had the Shift mph set to 58mph for 2>3 shift and RPM at 64
6,600rpm, but it appeared to shift at about 6,000rpm each of the 3 times I tried this. I will have to find a mph/speed/gear calculator to see what that works out to MPH wise as I didn't catch what the MPH was to see if it lined up with the 58mph or not. I guess it is also possible my tach was not keeping up at all, but unfortunately I wasn't logging it, so I can't go back and look.
Old 04-29-2023, 05:15 PM   #35
ZL1...SON
Found a calculator and 58mph should be 6500, so neither of those really line up with the 6,000rpm 2>3 shift that i saw... I'll have to go back and look at my tune to make sure I didn't fat finger a number. I'll be sure and log it as I don't think it was the tach not keeping up. It sure felt and sounded like it short shifted too
Is there an learning/adaptive process that could be happening and may take a few drives to line itself out?
