Old 02-06-2020, 05:46 AM   #29
Reddy1LE
Reddy1LE's Avatar
Drives: 1SS 1LE
This would be only accessible through hptuners? The last time I used tuning software was with my tactrix cable & ecuflash from the evo days...
What this car really needs is a notification eliminator. There's a wi-fi notification. Bluetooth notification. Parking brake disabled notification. Always some annoying notification popping up. - Navigator post
Reddy1LE is offline   Reply With Quote
Old 02-12-2020, 09:14 AM   #30
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
Yes HPtuners and EFI live are the only 2 consumer tuning/scanning software platforms worth a shit for GM.
Old 02-12-2020, 01:57 PM   #31
JANNETTYRACING
JANNETTYRACING's Avatar
What in the hell is with all this fascination over popping it sounds like XXXX
I want to completely eliminate it, nothing sounds better than a clean snarl on decel.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 04-25-2020, 07:18 PM   #32
Booher
Booher's Avatar
Drives: 2019 zl1 6 speed
So i decided to finally disable the dfco to see how it sounded. But my screen looka much different than the one shown, does anyone know why? Im a 17, and dont want to mess with the timing.
Old 04-25-2020, 09:54 PM   #33
Trochoidal
Drives: 2017 Camaro 2SS A8
Looks like you’re in basic view. Go to edit select view and than select advanced.
Old 04-26-2020, 11:16 AM   #34
Booher
Booher's Avatar
Oh good call, that was it, I changed both rpms to 8k and writing the file now. Thankyou for your help, as always. Fingers crossed it works and i didnt mess anything up
Old 04-26-2020, 02:04 PM   #35
Trochoidal
You’re welcome! I’d bet 99.9 to 1 that you’ll have no issues.
Old 04-26-2020, 10:32 PM   #36
Booher
Booher's Avatar
You are correct, it worked perfectly! Im gonna give it a week, but im not sure if i like it. I thought it would pop more, buts its more of a gurgle.
Old 12-21-2020, 01:00 PM   #37
MakCamaro
Makis
MakCamaro's Avatar
Drives: 2020 Red Hot ZL1 A10
So, was it worth it? Any feedback?
Old 12-22-2020, 08:24 AM   #38
Chrome383Z
Chrome383Z's Avatar
Drives: 2019 Camaro 2SS
I’m with you. If anything I want to get it tuned to remove it.
2019 Shock 2SS A10. 2650@10psi/LPE HPFP/XDI+30/LT4 LPFP+JMS/Soler 95mm/Rotofab, E65, CSP 2” Headers/GESI GenII Cats. MM Wild/GM SG3 suspension/1LE Brakes, Velgen VF5 Wheels/GY SC3. JRE Tuned.
Chrome383Z is offline   Reply With Quote
Old 12-22-2020, 09:32 AM   #39
He can certainly help you if you get stuck or are afraid to mess with the tables displayed above.
Old 12-26-2020, 05:53 AM   #40
MakCamaro
Makis
MakCamaro's Avatar
So I am planning to modify the min spark tables by doing the following: Instead of copying-pasting the whole top 3 rows of the 2019 table, I will reduce the timing in the Minimum Spark Base and Long Term to 5 degrees in the .04, .08 and .12 rows, as this is where I want the pops on decel. If 5 degrees of timing makes the popping rather aggressive, I will increase the timing values from there to fine tune the amount of pops and crackles.
This is what I will do:
Engine>Spark>Minimum Spark> Base and Long Term (Both tables)
First I will change 0.04 to 0.12 airmass rows by 2000 to 3100 columns to 5.00. I will go higher or lower in the RPM to suit my needs and also go lower or higher with the number to make more or less aggressive pops respectively. I 've been told not to go over 0.12 airmass rows.
I will try with DFCO enabled and then disabled, to see how it sounds and if disabling it affects drivability, deceleration and fuel consumption (not that I care). I will disable as geaux_tigerss suggested in post #23.
By the way, does anyone have the file in the first post of this thread? The link is not functional anymore. Thanks!
Old 12-26-2020, 09:16 PM   #41
Nitronut
Nitronut's Avatar
Drives: Duramax, 2018 Camaro SS 1LE
QFT!!!
If it ain't buckin, chirpin & makin all kinds of bad noises.... then I ain't happy!
Nitronut is offline   Reply With Quote
Old 01-25-2021, 01:36 PM   #42
cmcmro
Drives: 2019 Camaro 3.6 RS
What are you guys using to tune? I'm new to this and would love to get into it
Currently running straight through mufflers and a custom fabricated H-pipe and I'm getting wonderful gurgles on a stock tune, but I would love for them to be louder
cmcmro is offline   Reply With Quote
