Old 03-17-2020, 03:10 PM   #29
HyperBlueSS1le
HyperBlueSS1le's Avatar
Drives: 2018 SS 1le
Originally Posted by Trochoidal View Post
Hey HyperBlueSS1le that’s a nice install and good numbers. I did look at your install thread. https://www.camaro6.com/forums/showthread.php?t=537160
I have a few questions.
Are you still on pump gas, stock internals, and 7.5 psi?
Yes to all the above.
*Procharger P1x w/ stage 2 IC and big red BOV* Full LT4 Fuel System* New Era Performance cat delete pipes* MM Wild catch can* AWE touring axel back exhaust *P3 multi gauge *ACS composite Zl1 side skirts * Zl1 1le painted flowtie
HyperBlueSS1le is offline   Reply With Quote
Old 03-17-2020, 03:17 PM   #30
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
My the lord bless your ring gap and your ring lands.
ssmofo is offline   Reply With Quote
Old 03-17-2020, 06:09 PM   #31
Trochoidal
Drives: 2017 Camaro 2SS A8
Thanks for your answer. This is just the information I was hoping to read.
Old 03-17-2020, 08:15 PM   #32
oldman
Drives: SS 6 speed of course
would like to see the dyno please, SAE or uncorrected would be helpful.
Old 03-20-2020, 10:38 AM   #33
HyperBlueSS1le
Drives: 2018 SS 1le
You can see the dyno graphs at the one minute mark in the video I originally posted.
Old 03-20-2020, 04:07 PM   #34
DorkMissile
DorkMissile's Avatar
Drives: DZ
Originally Posted by jwaked View Post
No headers? That should help.
Full cat deletes vs long tubes are only worth about 5-7hp. Especially with a setup like this (7lbs of boost) - not flowing enough air or running enough RPM to make long tubes shine.
On the LT1, long tubes are just about the lowest return on investment being the stock manifolds are basically try-Y shorty headers
DorkMissile is offline   Reply With Quote
Old 03-20-2020, 08:15 PM   #35
oldman
I like the SAE graph, very broad torque band that does not fall off rapidly (blower moving more than enough air), nice peak numbers.
Old 03-20-2020, 08:20 PM   #36
oldman
Stock triY are nice the primary restriction is the driver's side cat it is crush bent down to 1.6" ID and has an 02 stuck in there too. I cut and widen mine to be round and wide, spaced out the 02 and ground away the 02 boss, also ported the intake transition. The is SOTP, but at my power leverl I would estimate:
ported Cat 12 to 15 HP over stock
CA cat deletes 15 to 16
LT headers 25 to 50 (not kidding) deppending on the tube size and cat /not cat.
Old 03-22-2020, 08:55 PM   #37
DorkMissile
Drives: DZ
I was referring to cat delete pipes vs headers with minimum gains. Really need to change airflow into the engine for the factory manifolds to be a point of restriction
Old 05-10-2020, 11:52 PM   #38
Tooktheglory
Drives: Chevy camaro
Do you have a ig bro
Tooktheglory is offline   Reply With Quote
