Old 11-15-2019, 02:19 PM   #29
GunMetalGrey
GunMetalGrey's Avatar
Drives: 2018 ZL1 (SOLD) 992 GT3 (current)
Update; dealership called me and said that GM told them to replace the entire fuel tank and fuel pick up assembly instead of just the fuel pick up assembly.
I sure hope they find some obviously wrong when they pull the tank out in a few weeks so that I can have some confidence that this issue is resolved once and for all.
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 11-15-2019, 06:51 PM   #30
Heartbreaker
Heartbreaker's Avatar
Drives: 2020 Camaro ZL-1 1LE
You should be thankful
Originally Posted by GunMetalGrey View Post
As the title says, I just discovered that my front GY SC3's are corded on the inside edges after 15 track sessions and 5,500 miles/4 months of daily driving with the track alignment specified for the ZL1.
I was surprised by this as I thought it would be the outside shoulders that would cord first, they sure look like they are about too as well since there are no groves or tread channels left on the outsides edges of the front tires.
I remember some forum members saying that the SC3R's corded first on the inside for them, so perhaps GY designed these similar in that regard.
Has anyone else had these tires cord on the inside before the outside? And if so, after how many track sessions and/or miles on the road?
That you got that much mileage out of your SC3s. Amazing! I got 6 track days and 4500 miles out of my set. Congrats.
Home Track: NCM Motorsports Park
Heartbreaker is offline   Reply With Quote
Old 11-15-2019, 10:07 PM   #31
GunMetalGrey
I had 15 track sessions not 15 track days.
How many track sessions did you have in your 6 track days?
Old 11-15-2019, 10:43 PM   #32
TrackClub
TrackClub's Avatar
Fingers crossed for ya. Good to see corporate GM taking an extra step here. Cheers!
Old 11-15-2019, 10:46 PM   #33
TrackClub
TrackClub's Avatar
Fyi i usually get 6 to 7 days out of mine. 4x30min sessions per day. I suspect your alignment issues played a role in yours cording prematurely. Cheers!
Old 11-16-2019, 03:50 PM   #34
GunMetalGrey
Thanks!
Old 11-16-2019, 03:53 PM   #35
GunMetalGrey
Yeah probably that and a really corner heavy tough track along with over driving.
Old 12-02-2019, 01:11 AM   #36
R3ctivision
1LE Convert
R3ctivision's Avatar
Drives: 2018 ZLE
Originally Posted by seanblurr View Post
It is normal on the Camaro platform. It is due to a dynamic toe change mid-corner when the inside, unweight tire basically gets a crap tone of toe out and is "dragged" through the corner. Nothing you can do to change it.
I've noticed this as well. Usually one of my front tires gets more outside wear while the other gets more inside wear at a given track. It's not necessarily clockwise/counter-clockwise, I think it has more to do with the tighter corners with more steering lock and more trail braking putting extra stress on the fronts.
I wonder if running a bit less front camber combined with more rear ARB and more rake could help? Idea being less camber -- less inside wear, but to keep from understeering, use the ARB and rake.
2016 Porsche 911 GTS (Racing Yellow)
2002 BMW Spec E46 race car (Lizard Green)
Previous cars:
- 2018 Camaro ZL1 1LE (Red Hot)
- 2018 Miata RF GT (Machine Gray/Auburn)
- 2017 Camaro 1SS 1LE (Summit White)
- 2008 BMW 135i (Montego Blue)
- 1996 BMW 328i (Arctic Silver)
R3ctivision is offline   Reply With Quote
Old 12-02-2019, 07:52 AM   #37
Repman
Drives: 18 Black ZL1-1LE
I think you should be happy with 15 and 5500 that is above average
Repman is offline   Reply With Quote
Old 12-02-2019, 01:14 PM   #38
TrackClub
TrackClub's Avatar
Yes for G3R. No for G3, which is what GMG was running on his ZL1. This is academic anyway as his alignment was *severely* off and likely ended up being dynamic due to poorly fastened bolts.
Old 12-02-2019, 01:38 PM   #39
TrackClub
TrackClub's Avatar
After 3 full seasons and many tire sets, at several (7) varying venues i have *never* experienced one tire wearing on the outside and one on the inside. I get near perfect wear regardless of CW or CCW tracks even without swapping rims L with R. Ovals excepted, rd courses usually offer 60/40 direction changes, so close enough...Also, going fast in fast sweepers causes much higher loads on tires vs going fast in slow corners.
Ive corded just one set of G3 fronts, both on the inside due to a very abrasive track surface, but both tires had the same, even wear pattern across at 2.6F 1.6R. So, perhaps your alignment has walked as was the case with GMG?
Also, *proper* trailbraking should help the tire wear vs cause it. But braking way too late, or not enough and overloading fronts into driver induced understeer will chew them up real fast. The solution is driver skill not car set up. NB PTM choice may also matter here.
Cheers!
Old 01-08-2020, 12:47 AM   #40
GunMetalGrey
Going to a reputable shop for the alignment next time instead of the dealership.
Old 01-08-2020, 01:29 AM   #41
TrackClub
TrackClub's Avatar
I lucked out at a dealership, but only because their alignment tech was a circle track racer and he sure knew his stuff! Keep in mind it is a good idea to check the alignment after an event or so, just in case. Id ask that such verification (and correction if necessary) is part of the original price. Fyi: mine has lasted 3 seasons! Best of luck and cheers!
corded, goodyear, sc3, track
